Cars & Trucks Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
For a month now my air control knob will only work on the highest setting. Just an hour ago my car quit blowing air all together and my air control know is VERY HARD to turn. I try turning the heat on to the floor and I hear the motor but nothing happens.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 142 Answers
  • Posted on Dec 10, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
142
Questions
Helped
33134
Points
414
Unplug the heater motor and put a hot wire to it to check the motor if it blows if the wire gets real hot you need to change the heater blower motor. You will probably need to change the heater fan motor resistor. follow the heater fan wire and it will go to the resistor
  • mjc234u Dec 10, 2010
    I am not mechanically savy...so if I take this to a mechanic I am sure they can do this. How much would it cost to replace these parts? Also could the knob be stripped also? If so can they just replace the knob?
  • Anonymous Dec 10, 2010
    he knob is cheap you can get it at the gm dealer parts department just pull it off and push the new one on around $20.00. If you need the motor it will run 200 to 300 to fix it.depending if you need the resistor to.
Ac blows hot air
I have had a similar problem quite a few years ago. You don't mention the model or year of your vehicle. It could be a relay that is on the firewall just below or behind the firewall in engine compartment in front of driver's side of the car. It took a really savvy MB mechanic an hour to locate and fix after 2 months in other shops, including an MB dealership. Mine was a 1988 560SEL that had that problem. After that was fixed, it worked perfectly for another 5 years - at which time I sold the car.
I hope this helps...
2002 Chevrolet Malibu blower motor weak in all settings.
resister switch may be weak, replace it, it looks like a coil spring, under dash, also clean all connection @ blower motor under hood
Air does not blow
The car normally blows air through the blower however the controls and settings of the speed of the blower are controlled by the blower motor resistor. The resistor controls the speed of the blower fan. If your blower still works on the highest setting then the blower itself is still in working order. If you are not getting any air at all, even on the highest setting, then chances are the blower has gone bad, blown fuse or open wire. If this does not help please give us more information to work with.
1helpful
A/C will only blow on highest setting
Fan speed control resistor block is the usual suspect for this. Quite in-expensive $10 - $20 ?
Easy to change, usually. Generally under the passenger side dash mounted in the air flow comming from fan. Maybe 2 - 3 screws on a block with a few wires, looking like it leads into the air cowling. May be behind glove box.
Do not run fan with new resistor out side of the air flow, it may burn out very quickly without the air blowing on it.
12helpful
3answers
Air conditioner doesn't blow with much force
Refrigerant is not your problem!!!!!!!!
Your recycle door has broken off and fallen over the suction duct to your blower. You can verify this by removing the blower under the dash on the passenger side. Reach up into the duct and if there is a plastic door obstructing the duct, it has broken off. With a little manuvering you can remove the broken door through this hole and you will have air again, just no control of inside or outside air. Dodge has redesigned the housing for this recycle door which is supposed to stop this from happening. The redesigned housing and door come as a unit from Dodge for about $30.00 and this includes the electric actuator. This requires removing the Dash to change the housing so if your not ready for several hours work, take it to a mechanic.
6helpful
2answers
A/C will suddenly send out heat. Fiddling with knobs seems to help. What's wrong?
You have a broken wire connection between the temperature control knob and the circuit board behind the center dash console. Vibration causes the failure and once the control knob gets loose the solder connection fails.
For someone that knows how to remove the dash unit and can re-solder a couple of new wires this fix should take no more than 1 hour. Make sure that you apply loctite to the heat control knob spindle nut when you re-assemble it.
The dealer quoted me 750 dollars to fix this issue and I found out that it's a common failure for this year. I fixed mine virtually for free but it took some tools and about an hour of my time.
2answers
Ac controls
selector mode switch is bad
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
The heater only blows hot air
You didn't mentioned the model year of your Ford, but you might try lubricating the heater control switch which is located in the engine compartment side against the firewall. If you have someone try to move the temp knob inside while you look in the engine compartment, you might find the control valve. Once you find it, check to see if the cable is still connected, then try lubricating it with some WD-40 at 1st to get it sliding like it should. Once the cable is opening and closing the valve like it should, you will notice the temps adjusting like they should. Good luck!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
