Question about Acer AL1912 19" LCD Monitor
GREEN DOTS MY PROBLEMS IS ALOT OF SMALL GREEN DOTS THAT POPS ON THE ENTIRE SCREEN, THEY COME AND GO WHAT CAN I DO
    President:
  • 173 Answers
Try adjusting the resolution on your monitor or the color. Make sure that the resolution is also adjusted properly in your computer system.Hope this helps and if it doesn't please let me know
Posted on Jun 29, 2008
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
There are thousands of small blue dots on the screen of my Sony KF-42WE610 that make the pictures look rough. Additionally, the pictures are too green in spite of color adjustment. How can I fix these 2...
both problems would most likely be fixed with and optical engine replacement. due to cost it may not be economical to repair new purchase may be smarter. part number---A-1606-006-A $668.51plus tax and labor.
Dec 22, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
I have "green" dots or "green" tint in the entire screen.
Here you go old chap:
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=36&NAVDISP=tv
Cheers.
Nov 11, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Growing number (now six) small green dots on right side of screen of 65" DLP rear projection Mitsubishi HDTV. Annoying -- how to fix?
Replace Light Engine, pretty soon you will have Dots All over screen with green and purple color. Call UED for price of rebuilt Light Engine 1-800-648-6657 ask for Melissa tell her ladywinn said Hi.
Sep 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Screen freeze, with green dots!
Its a small group of solder balls 3-4 under the GPU that
have broken in to thhreads , and will disconnect all together
from the main board , it some time will start with a flickery
screen during start up .
The only permanent solution is to dig a hole.... just kiding
The GPU will need to be re-flowed and properly secured to
the PC board .
That fixes the problem permanently
and that goes for 98% of all of The 360s problems
Aug 24, 2009 | Sony Playstation 3 (PS3) Console
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Trying to get into downloading victorchandlerpoker.com running as if downloading and small screen pops up and nothing further ???get to downloading section and it starts with green dots and just as it...
might be your popup blocker, you can try turning it off in the internet options on the privecy tab in the control panel or when you click on the link press ctrl right after to overwrite the popup blocker.
Sep 17, 2008 | Computers & Internet
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
GREEN DOTS ON SCREEN PANASONIC PROJECTION HDTV 1080I
Ah, big no-no.
This is the result of the coloring being pulled to the front of the screen.
This is caused by magnets. Anything magnetic will cause this, even a small one.
Hopefully you have warrenty, this is pretty expensive to replace.
Jan 02, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Flickering dots
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Jun 03, 2007 | Toshiba 42HPX84 42 in. HDTV-Ready Plasma...
Acer AL1912 19" LCD Monitor Logo
354 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
