Question about Dryers
My convair millenia is not working well
It doesn't seem to be working. the filter is not soaking with the water and consequently the air is not coming out cool, how can we fix it or at least know what the problem is?
Had the same problem. Did all the the abpve solution #1 & #2. Still could not get water to the filter pad. My problem was the diverter switch (left blue switch for cool or drain was striped so that when turned the diverted remainded in the off position. Used pliers to move to cool position and it worked fine.
Montereyjack
Posted on Jun 03, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
Ok. 1. The Convair Millenia is an evaporative cooler, so i dont think it should be placed under the fans section...
2. There are various problems which could be associated with your cooler not functioning properly, in your case the cooling aspen pad is not getting soaked.
to solve this:
1. The pad could be not soaked by the cooler because there is blockage to the water flow chanels to the aspen pad. To fix this, open the cooler at the back, mine has these two blue tabs (you need to push on those to wedge the cover out).
Once you have done that, you should now see pad, remove the pad gently with the cover, and place down. Then, now what you should see is the water channel (located on top of where the pad was), it has small water channels spreading out from central.
We now need to clean this channel, to do this, simply use your finger to open the cap, the cap is the blue/purple cover with the hatch. About the size of a 2l milk bottle lid. Once you have opened the cap, clean the hole of where the water comes in and gets dispersed through the channels. There might be some dry wool **** in this small section. And maybe some are hard to get out, but please try and do so to make your cooler work properly as it used to. Once you are finnished, just do the reverse of what you did to open the back cover. =)
2. another fixable problem could be due to the cooler's control pad for cooling is not set to cooling. Please check the nob is twisted and is directing to 'ON/COOL(this varies with the models, yours should say on or cool)' not '0' or 'OFF', to be the most sure, the cool/on selection should be the rightmost.
3. the elastic cord pulling the pump to pump up the water is broken, or worn out. If you can fix this contact Convair (from yellow pages). to replace it, remove the back cover and pad, look on the blue plastic shield, ther should be a small window to acess the cord and to replace, just simply open that and take out the broken cord and replace with your new one.
I hope this fixes your problem. I own one made in 1999 and i have taken it apart once every cooling season to clean it and clean the water channel, as well as replacing the pad.
Thank You for submitting.
=D
Posted on Dec 12, 2009
We drained the water and fill it up again and started to worf fine. we think that maybe we filled it up too much. thank you
Posted on Jun 30, 2008
Convair Model cm12rw , it is making too much water for the supplied drip tray, it was not making any , then it overflowed !
it causes due to moist in air. no need to worry. just add a curtain beside ac near abt 1 meter away. it is helpful
Oct 14, 2013 | Convair Portable Air Conditioner
I do not have a user manual for my Convair Millenia Model MI Ul Prod. No. 009100 evaporative room cooler. Where can I go to download one? Not having any luck at the usual sources. Thanks!
I have an Owner's Manual for the Millenia Convair MI that I would be willing to scan and email to thesmiler (problem at the top of the page). Is that possible?
May 13, 2011 | Convair Heating & Cooling
Free standing Convair Supercool leaks like a sieve! We have no manual. Does the small black hose pipe drain the water from the white pipe at the bottom rear of the unit [ where most of the water is coming...
The water is being generated from humidity inside the air. The air conditioner also acts as a dehumidifier. The black line is the drain. The drain line needs to go to an outside line or to a container to collect the condensated water. With low humidity levels, the water will evaporate back into the air. With high humidity, the water is removed from the air at a higher volume than can evaporate back into the air.
Jan 29, 2011 | Convair Portable Air Conditioner
I have a Convair Westwind air cooler that you fill with water. I have lost the plug that holds the water in. Can you send me one (or two) of these plugs?
Howdy, we have no affiliation with Convair corp. As we are a general solutions and technical assistance with everything website.I have, however found the contact info for them :
CONVAIR COOLER CORPORATION
I hope you found this useful, thanks for using fixYa.com. Farmerbear
Sep 02, 2010 | Samsung AW1203B Air Conditioner
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Air Filter soaked with gas
Clean It with soap and water and afterwards let it dry and put a little bit of motor oil on the filter. You may want to check your petcocks because they may be leaking. Be cautious when you ride with a gas soaked air filter the airbox may catch on fire if the motorcycle backfires which I have experienced in the past.
Jun 26, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
Dryers Logo
738 people viewed this question
Top Dryers Experts
