Question about Sportline Watches
Sportline Solo 900 [ ladies]
Posted my problem in wrong place. This looks much better.
Put my watch on today, time correct on face, but when I pressed the button to check pulse, everything went blank. No matter which of the4 side buttons I press, nothing happens. There is a high-pitched whine from it, when placed at ear level.
Does it need a new barttery? Where do I have one replaced properly?
I only bought it a couple of months ago, and, unfortunately, threw out the instructions with the wrappers.
Thanx for any help, I can get,
Scotty
  • Anonymous Jul 03, 2008
    Goodmorning Robotek,
    Thanx for the solution for my watch problem.
    I did as you suggested, and was fortunate to have it exchanged for a new one, by a very helpful young lady at Sears, where I purchased it, so all is well.
    My email from your company, is saying i have another problem to be solved, but there was only the one, and you solved it.Perhaps, because I had posted it in the wrong place, Please erace it , if need be.
    thank-you,
    Scotty
  • 2,071 Answers
High-pitched whine sound is the sign that battery is going to run out , the battery is need to replace ,the size of the battery is SR 2025 or lithium replacement 2025,any brand Maxell,Everyready,Toshiba,Seiko and Renata..
This is very easy to replace,you need only a jeweller screw.and a piece of hankerchief.... at the back of your watch there is four small philips screw, when going to unscrew put the hankerchief at the pad where you going hold to open the watch, hold the watch firmly when unscrew to avoid unwanted scratch.If you already open you can see inside tin plate cover the battery,.The battery is in the center ,find the end of tin plate that covers the battery,if you see the end twist it so you can take out the battery and replace it with a new one ,then your watch is working again..
When closing the cover make sure the gasket(black rubber) is in place ,so water can't get inside, then screw the cover.
Dont wory your watch it is 30 meter water resistant..
You can buy the battery in local grocery store ,or electronics store,the battery size is common just give the size number...
i have site for free manual; .
http://www.sportline.com/manuals/900.pdf
Posted on Jul 03, 2008
    Master:
  • 638 Answers
Its simple the battery is faulty but before replacing the battery just remove the old battery and try to insert it again by giving it mild warmness through dryer the problem can also occur due to moisture in it.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 29, 2008
  • 405 Answers
Good Day,
Battery replacement is a good start. Any jewler in your area should stock the battery and install it for you at a resanable price. You could also take it to an electronics store, however they may only sell you the battry and not install it.
The best advice I can give is to replace the battery , If you still have this problem then there is another issue to address. Those battery's usually last a year or two, I could have sat on a shelf before you purchased it thus depleteing the battery.
Hope this helps
  • 13,433 Answers
Heres the manual
To me it sounds like it may have got wet or damaged.
Do you have warranty on it? You may have to send it for service.
  • 1 more comment
  • Ekse Jun 29, 2008
    Battery
    Battery replacement will be required from time to time,
    and should occur when:
    • The display fades in part or completely
    • The Heart Rate function will not activate
  • Ekse Jun 29, 2008
    If replaceing the battery doesn't solve the problem, you may have to take it in for service.
    Let me know if you need anything else,
    Thanks,
    Ekse
  • Ekse Jun 29, 2008
    One more thing about replacing the battery - from the user guide:
    To replace the battery of your Sportline Solo 900 Heart Rate Watch,
    we recommend that this be done by a watch repair service center.
    This will ensure that the water resistance will be retained after battery
    replacement.
    The Watch uses the standard lithium replacement battery: 2025"
  • 1,512 Answers
It will need to have the battery replaced. , i would take it back to the store that you purchased it from and request that they do it for no charge for you. They will do this for you. Great customer service.
regards
robotek
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
Sportline Solo 910W Heart Rate Watch for Women instructions
You can get instructions by going to http://www.sportline.com/category.php?cat=4
and and locate your watch from the list and clicking on your model.
Now click on "more info" and you will find a tab marked "manual"
Oct 30, 2011 | Sportline Solo 910W Heart Rate Watch for...
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
How can I tell what jewelers are qualified to replace the battery in my Sportline 900?
just bring it to the authorized retailer of your watch because they really know ho to change your watch battery
Jul 11, 2011 | Sportline Solo 900 Heart Rate Watch for...
The heart rate function keeps saying its off; how do i turn it back on?
Here is the pdf version of the watches manual: http://www.sportline.com/manuals/900.pdf
Press the bottom metal sensor until the display flashes. Says its best to use the "flat pads" of your finer and not the tips.
Good luck.
RJ
May 09, 2011 | Sportline Solo 900 Heart Rate Watch for...
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
How do u set the time on a ga 100 g shock watch
You hold down the A button for a few seconds until it beeps. The A button is the one that says 'adjust' on it and is at the top left hand corner of the watch face. After that you adjust your home city time by pressing the bottom right hand button. After you hit adjust again the watch face will rotate to the home city time. You can see your home city change in the bottom right hand lcd display. A description of the home city codes is in the manuals you can download from the site posted above
Jan 10, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Watches Logo
323 people viewed this question
Top Sportline Watches Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Sportline Watch Expert? Answer questions, earn points and help others
