Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hampton Bay 54" Caswyck Ceiling Fan. Just installed this fan. Prior to lifting onto ball hanger, I tested it with the remote. both the fan and light worked. After putting it into the ball hanger only the light would work. I removed all wirenuts and retwisted wires and replaced, no fan (light still works). I inspected wires for nicks, none. The receiver clicks when I push fan but nothing. Is the reciever bad already?
  • Anonymous May 12, 2009
    I have the same problem with this remote receiver. Best way to fix it - buy another ceiling fan, replace remote control units and return back were you got it from.
5 Suggested Answers
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
How to install Hampton bay fan #CF 004-52 on a slanted ceiling
I'm an electrician and can help you with your question.
Most (if not all ceiling fans) are designed to hang from most ceilings - flat or angled. This is done through the use of a molded plastic ball secured to the downrod of the fan assembly, that will allow the fan to "self-level" in the hanger
A special "hoop like" hanger is secured to the fan rated electrical box that allows the fan to hang straight down - providing that your ceiling isn't at a real freakish angle - all by itself. The only other thing to watch for is the blades. This is especially true if the new fan has larger blades or a shorter downrod than the old fan. Make sure that the fan blades will clear the ceiling (and enything else for that matter) when running. Otherwise, you will need to use a longer downrod to allow the fan to hang a little lower. Make sure it is not too low to prevent it from striking people walking below it.
Review the installation manual and check out the support "hoop" for the electrical box and the downrod with the plastic ball on the end (may require assembly of the ball to the downrod). You can install the support hoop and hang the downrod to make sure you understand how it works without assembling the rest of the fan.
If you have any problems, you should contact Home Depot (Hampton Bay is a Home Depot house brand) for support.
Mar 28, 2013 | Hampton Bay 04345 Cruiser Ceiling Fan
The remote transmitter for My Hampton Bay Windward III 54" ceiling fan operates all fan functions properly; however, the lighting functions do not work with my remote. How can I check out problem?
The good news is that the fan functions properly. Now, do the following.
1. Turn off power to fixture at the breaker
2. Remove batteries from remote and press all buttons to eliminate a stuck button as a cause. Reinstall batteries
3. Turn on power and test operation of remote. Be sure to hold dimming button down until lights respond
Jan 29, 2013 | Hampton Bay Dryers
I am looking for a Hampton Bay sauterne ceiling fan. Do you know where I can get one
Hi msslillylu...
Go to the following webage and purchase your Hampton Bay Sauterne Ceiling Fan.
Please take time to rate me thumbs up
http://www.kaboodle.com/reviews/hampton-bay-54-in.-sauterne-antique-umber
Sep 14, 2011 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Need remotes
In theory, they should. Try Hampton Bay first, and if not, check for aftermarket replacements. Those remotes are simple enough that there is no reason that they can't.
Dec 18, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
901 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Fan Fair Of Boca
Fan Fair Of Boca
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
