In setting up this printer, we are unable to make a copy as the setting for paper thickness comes up. We keep getting a ringing and somehow cannot get everything set. We do not have it hooked up to a computer and do not plan to do so. This is to be used mainly as a copier and fax for a non-profit organization. Is it possible to get a manual for this machine?? We just purchased it a week ago.
Help me to receive a singular report when I send a fax
Hi patmenkl - below is a link where you find your manual. There is also a quick start guide and and easy setup instructions if you need. If this is what you were looking for PLEASE rate this as fixed. This site can be slow so give it a minute. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Jeff
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
