Question about GE GSS20IEP Side by Side Refrigerator
GE Side By side doesn't cool and freexer frosts up
We have a GE side by side refirgerator its about 4 years old. The freezer gets about as cold as the fridge does and the fridge doesn't get cold at all, plus the freezer frosts up on the insde.
We had a friend look at it and they said that they thought it was the control board because it's not going into defrost at all. We replaced that yesterday. I defrosted the inside with a blow dryer before we replaced the part. Once we plugged it back in it was running all night but it never did get cool. Now this morning it is frosting up on the back of the freezer again. ANy suggestions?
  • 473 Answers
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Posted on Jul 14, 2008
We have a GE side by side refirgerator its about 4 years old. The freezer gets about as cold as the fridge does and the fridge doesn't get cold .
Posted on Jul 08, 2008
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a side by side GE unit. The bottom of the freezer compartment keeps the food frozen but the upper half of the freezer will not freeze. There is a motor or a fan running on the freezer side and frost...
Try to defrost the freezer and see if the air valve opens and closes properly if all of that works then there is a problem with the fan that moves the cold air into the refirgerator
Mar 06, 2011 | GE Freezers
Why is this ge side by side refirgerator not cooling on one side but the freezer part working?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
AN OLD GE FROST FREE BOTTOM FREEZER REFIRGERATOR. LIGHT IS ON BUT DOES NOT KEEP ANYTHING COLD. THIS IS AN OLD AVOCATO COLOR REFRIGERATOR WITH A BOTTOM FREEZER. I AM FAIR WHEN IT COMES TO REPAIRING THINGS....
Wow avocado green! Didn't know bottom freezer models were made that long ago. Make sure all fans and compressor is running. If all that is running and still not cooling, time to get new Fridge.
Sep 27, 2017 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side
Something has gone bad in the defrost circuit.(Heating element was notorious for this) but could be a timer or thermostat. Frost buildup will cause inefficient cooling as will dirty condenser coils.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Side by Side fresszer frosts up and it doesn't cool properly
possibly you did not defrost enough but other things to check are:
does the fan operate?
maybe the defrost element open circuit or the thermal cutout in series with the element
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Side by Side stopped cooling
This sounds like the defrost heater is bad or dead. The refrigerator will not cool because frost is building up on the evaporator coils in the freezer section and the fan can no longer push air past the coils. You will find that the freezer will build up with frost.
If you are brave enough, remove the cover in the freezer and you will see the coils are completely covered with frost (ICE). At this point with the refrigerator unplugged ( remove food). get a hair dryer or heat gun and melt all the frost. You will notice a heating element ( looks like a tubed light) -element will looked burnt out.
Replacing it at this point is easy. Before you start though, try to get the manual for your system and call around for a local appliance parts store to see if the part is readily available.
Nov 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
285 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
