I need the component to my tv that the cable connector is on.
  • 8,617 Answers
I would need the model number to even begin to help you with locating one. Please respond to this same post when posting the model number.
Posted on Jun 29, 2008
WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Oct 24, 2017 | iLO Televison & Video
How do I connect my TV to a cable DVR box?
The simplest way is if your cable box has HDMI (wide flat connector tapered at the ends) then connect one end to the cable box and the other end to the TV input and you are done. If your TV or Cable Box does not have HDMI connecor, then you can connect it through COMPONENT VIDEO + AUDIO. Component video is the red-blue-green connectors. That is video only. Then you need to connect red and white audio connectors from the box to the TV as well. Total of 5 connections. When you are done, make sure you have your TV selected to the input corresponding to the input you are using since most TVs have multiple inputs in the back and side of the TV. G
Mar 30, 2015 | Televison & Video
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
How do you connect AKAI model # PDP4290 to cable ?
You will need a cable box/set-top box with this TV. Contact your cable TV provider for this.
It does not have a direct RF connection, only AV connections.
For Cable TV support you can use
  • Composite video (single RCA connector)
  • SVideo (round 4 pin connector)
  • Component Connectors (3 RCA connecters red/green/blu)
Component will give you the highest quality signal (as long has the cable box supports this connection) You will also need to connect the Audio connectors (red/white RCA) from the cable box to the TV as well.
The full PDF manual for your TV can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0502572.pdf
I hope this helps,
Magoo
Mar 11, 2011 | Televison & Video
Why does the tv have component video when its an analog tv and how do you hook it up
Component video IS analog. It is also known as Y-Pr-Br. These connections are typically RCA connectors colored Red/Green/Blue.
Component will give you the highest quality signal for analog connections (vs Composite Video (yellowRCA) or S-Video(the round 4 pin connector) Of course HDMI will be best if it is supported.
Keep in mind video signal formats are NOT interchangable, you cannot plug a Composite Video into a Component Input
All you need is a component source (typically a DVD player) and 3 RCA cables and match the colors up.
You will also need to connect the Audio connectors (Red/White) with RCA cables, as the Component is Video only
I hope this helps,
Magoo
Mar 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
How do i connect my laptop to my television
You need a VGA to TV cable. If your TV has a component input, you need a VGA to component cable, like the following one:
http://www.amazon.com/Male-3RCA-Component-Video-Cable/dp/B000SJ2TJ8/ref=sr_1_9?ie=UTF8&s=electronics&qid=1266279733&sr=8-9
The VGA connector is for your laptop (you connect in on the side) and the RCA connector (3 plugs) is for your TV
Check your TV for a green, blue and red connector on back.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 16, 2010 | Toshiba Satellite L505ES5015 NoteBook
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
