Question about Vacuums
Filter keeps clogging
Dust etc collects in the filter above the dust containner. The dust containner remains empty. Hoover then over heats and cuts out. collect in replaced new filters in hoover but problem stiil remains.
  • denise_kye Dec 28, 2008
    the filter you pull out in the case of a dyson keeps collecting all the dust and rubbish then gets stuck and the hose wont **** tried changing to a new filter problem still there.
  • Anonymous Mar 15, 2014
    Suction is okay but dust collecting at base of chamber. Filter is clen
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
MY HOOVER 199W JUST STOPPED WORKING.............I'VE CHECKED THE FUSE AND EMPTIED THE DUST....STILL NOT WORKING...ANY SUGGESTIONS PLEASE THANKS Veronica
It could be a thermal breaker that goes automatic if the filter is full of fine-dust and the rpm of the motor becomes to high and the heat dissipation will acces the thermo breaker replace dust back AND filter, second there could be if the brushes are become to short the autostop can be activated (you see a little dark pin with micro spring in the brush ) in one of the 2 carbon brushes. if so replace the carbon brushes .
A Switch or cable defect (measure it)
Aug 02, 2016 | Hoover Vacuums
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
Can I wash the filter in my dishwasher?
I would not recommend it. It's not good for the filter. It may cause it to disintegrate. Getting the fine dust wet can cause it to clog the pores of the filter restricting the airflow. I would not want any of the nasty contaminants that collect in a filter to possibly be able to contaminate any items like plates, cups, silverware, etc. that are used to eat.
Feb 25, 2015 | Hoover Vacuums
Beater brush stuck on (keeps turning) in upright position and no hose suction with Hoover U5753-900 WindTunnel Bagless Upright Vacuum. I have tried adjusting the brush level up and down and moving the...
HI, it's Jim from Crucial Vacuum!
Your Hoover may be losing suction in the hose and having an issue with the brush roll due to a clog within the vacuum, or possible debris stuck on the brush roll itself. Here's some tips that will help.
First off, if your brush roll just keeps turning be sure to turn off your vacuum before examining it. In regards to the lack of suction in the hose there may be a clog in the vacuum itself.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction, for the hose as well.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Lets look at the hose itself. Stretch the hose out entirely to see if there are any clogs within. A handy way to unclog your hose is to use a broom handle or coat hanger. Make sure the coat hanger is a plastic one. You don't want to tear the walls of your hose.
As for the brush roll itself. Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. Also, manually spin the brush roll to see if there are any clogs or debris stuck within.
You can purchase replacement parts for your Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+windtunnel&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 14, 2014 | Vacuums
How can I get my DC26 working?!
They can cut out due to overheating. Although you say you have 'cleared' the filters, they should ideally be washed as they can clog with very fine dust and cause overheating due to lack of air flow. Once a machine cuts out due to overheating it can take maybe half an hour (or longer) to cool down enough to work again.
Aug 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My vax power 8, 2200 watts 300 air watts 4L capacity upright Hoover is brand new, I emptied out the dust/dirt collecter and cleaned the motor filter yesterday for the first time, i switched it on and all...
I had the same problem. It looks like the seal on the lid on the bottom of the cylinder has fallen out when it was emptied. There is no longer a proper vacuum being created so you don't get the cyclone effect and the dirt doesn't collect where its supposed to. it just clogs up the filter. I put sellotape to seal the lid and it works fine.
May 14, 2013 | Vacuums
I vacummed some sheetrock duct up with my hoover elite cyclonic.. i dumped the canister to empty the dirt and dust, but now theres not as much suction... is there any other area I should be cleaning... or...
do not put the filter in water, it will ruin it. if banging out the filter did not work than you should probably replace it, sheet rock dust is very fine and will easily clog most filters.
Aug 20, 2009 | Vacuums
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Vacuums Logo
175 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
