Swintec SW20 Portable Cash Register Paper feeding
Hi.
I have lost my manual and cannot figure out why the paper is not feeding as it calculates.
Also It has been a while since I used the register and cannot remember how to even thread the paper through.
There is a black removable spool that sits in a cradle in the paper tray, just cannot remember how it all threads through.
Thanks for your help.
Regards.
Dunderhead!
  • 3 Answers
I was wondering if you ever found the solution to your issue, as I am having the same one. I have the SW20 Swintec manual and it does not help with troubleshooting.
Does anyone have any ideas?
Angel
Posted on Jun 07, 2010
  • 682 Answers
Please confirm that paper path is clear from any foregin object droped inside(pins-stapler-small pieces of torn paper).
regarding manual you can buy it on line(it is not free of charge).
Posted on Jul 02, 2008
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
How do I change register tape on 500dx electronic cash register
There should be instructions where the paper feeds in. Usually, you follow the rollers with the paper and feed it in. Did you try google.com for you instruction manual?
Nov 17, 2014 | Royal 500DX CASH REGISTER
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Problem with paper roll feed - does not finishing feeding through on transaction need to manually feed to get the whole receipt
hi top of the left side on the cash register their is a button its shape like a arrow .it is the paper feeding key if you wont to manually get the receipt press it
Jan 05, 2011 | Sharp XE-A402 Electronic Cash Register
Need to program a Royal er 125 cash register
I have a copy of the manual if you know how to thread the paper tape. I need a picture of the workings, to make sure that no parts are missing to do this. I figured out how to change the ink, but can't figure out the paper path so that it will feed past the ink roller.
Email me back if you can help. shannon165@gmail.com
Sep 18, 2009 | Royal Office Equipment & Supplies
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Canon Calculator
Okay just figured this one out but on the back of the claculator there is a slip slid paper in that Press the feed key and allow the paper to feed through the claculator if it doesn't feed through push the paper in a little and hit the feed key again. It worked for me
Aug 18, 2008 | Canon P170-DH Calculator
Changing the paper feeding roller in a cr 110 cash register
hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Apr 11, 2008 | Casio Parts Cash Register PC Desktop
614 people viewed this question
k24674
jasbo
jasbo
