Question about GE (PSS26MSRSS) Side by Side Refrigerator
Brand new GE wont get cold
We bought a brand new GE 25 cu.ft. french door freezer on bottom yesterday and the temps say "OF" I put it on turbo freezer and turbo cool, and I have set the freezer to -2 and the fridge to 38 (recommendations). Both flash -2 and 38 for about 3 seconds and then the display reverts to "OF"
food is now ruined (24 hours - all freezer food has defrosted).
Pissed off. Please help.
Anita
  • 54 Answers
Sounds like the installers had to remove the doors when the unit was delivered. If they did they might not of hooked the wire harness up at the top of the door hinge or damaged the room thermisters at the top of the door hinge system. Also there is 2 magnetic switches under the top of the doors, you might check the wires on them as well.
Posted on Jul 03, 2008
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
My amana 25 ft bottom freezer stopped cooling
what you might need is a new Compressor part number W10566381
the pic below is the Compressor that you might need
Oct 06, 2012 | Amana 25" Cu Ft French Doors Bottom...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
147 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
