Question about Labtec Wireless Desktop Keyboard/Mouse 967263-0403
Mouse freezes up have lost startup directions
Need startup directions
  • 96 Answers
First check the connection of your mouse into you cpu and then try to check your bios, set settings of your mouse.. Then save the configuration. Try to start you computer.
Posted on Jun 29, 2008
Mouse freezes up right when startup begins
Hi, make sure the drive is right for mouse, update the drive, if problem persists it will be necessary to replace the palm rest ( mouse pad)
Dec 16, 2013 | Toshiba Satellite M35X-S161 Notebook
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Sep 22, 2010 | HP Pavilion dv2000t Notebook
Mouse keep freezing , i did clean the mouse thinking its was dusts but it keep freezing did unplug and try other usb ports , same probleme
if you are using windows xp it does have some problems. update your copy of windows using windows update, or remove too many programs on startup and/or reinstall your mouse driver if it includes one.
Jun 19, 2010 | Dell U0636 Mouse
Why does my toshiba satelite keep freezing up after startup ?
Try to restart it and make sure any accessory plugged into it is unplugged. i.e. ipod,mouse,external hard drive. If still freezing up, see if you can get to task manager, by pressing the clt,alt, del keys all at the same time the manager should pop up. then click on the performance tab, and see what your cpu usage is at. if its pegged at 90% or higher and does not get better you have lost your hard drive...I would also try a system reboot to refresh the system if you can just to make sure its not software related good luck
Apr 13, 2010 | Toshiba Satellite L355D-S7815 Notebook
I cant get the mouse to work, need to re install but lost directions
Go to manufacture's web site and see if it is available for download
Feb 15, 2010 | Belkin Mini Wireless Optical Mouse...
Laptop has trouble staying on and when it does the mouse freezes up as soon as desktop is loaded
1. remove all unnecessary items from the startup
2. update mouse driver
3. try booting Windows in safe mode if things work OK there,
4. try booking with more drivers.
Sep 13, 2009 | Toshiba Satellite M45-S265 Notebook
Acer 3000 Loads properly then the mouse and keys freeze
Goto Start>Run and type msconfig then press enter..In that window goto startup tab & disable the programs you dont required to be loaded at startup...
Nov 29, 2008 | Acer Aspire 3000 Notebook
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
70 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
