Question about Kitchen Ranges
I want to replace an erratic element on a really old Viking stove. The new element plugs into a new recepticle,but the latter has 2 wires, whereas the old stove has 4 wires that were connected directly onto the range (plus another wire-temp guage). Which wires go where?
  • Anonymous Mar 14, 2014
    An old stove with a 4 wire stove plate needs to be replaced. The later models have only a 2 wire replacement spiral plate. Which of these wires do I connect onto the new 2 wire plate?
This can't be done. The old elements were a two part element with 2 seperate coils. The heat was controlled by using one or both elements at different voltages to select the heat output. The new 2 wire element just pulses the current on and off to control heat. It is just one big element. Try to purchase a generic replacement burner that will fit the hole. Usually these come with the chrome ring and everything. They are somewhat adjustable but will not match your existing burners. GE used to make this. Another possibility is if the control to the burner is a knob that turns, Replace the switch with a new infinate heat switch. If this switch will mount properly. Just grab the two 220 volt legs from the old switch, Ignore and tape the neutral, ground, and pilot leads. Connect to the line side of the switch. Use only 2 of the old wires going to the burner and connect them to the new one.
Posted on Jun 29, 2008
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct Bake Element for Viking Range, PJ010004: Appliances
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
Replace oven element
Really need to know what type of oven it is. the element is either one of two types. It will either have a socket arrangement where the element simply plugs in or the element will be hard wired. That is to say it will have wires going from the element to the oven simmerstat. If it is a plug arrangement you will usually have to unscrew a couple of retaining screws at the back of the element where it attaches to the oven back wall to remove. If it is the latter just unscrew the wires and replace like for like on the new element. Cheers
Feb 28, 2014 | Fisher and Paykel Kitchen Ranges
Make extension 220 volt cord for 220 volt welder
most 220v welders have a NEMA 10-50 plug or the NEMA 6-50 plug--the input /output ratings thru recepticle and thru plug are same-configuration of plug prongs are different( Grainger Catalogue shows simularities and differences) main difference is AC Horsepower Ratings are different, and that applies Only on equipment that uses 3 phase, not your welder.Use an Ohmmeter to touch unpowered wire connection under shroud at ground and plug prong, then red power connection to corresponding plug prong, and again to black connection and plug prong,mark them w/ felt pen w/ corresponding colors (Green, Black Red). Change out wire plug to fit into dryer or stove recepticle, or make an extention adapter plug witch fits stove recepticle and extends out thru floor to carport and goes to 10-50 recepticle-whereas ground green goes to W position (Center) Y is Black and goes to Y Black, X is Red and goes to X red and cap off the white neutral coming from plug -welders and hot water tanks do not return unused electrcity via the white neutral (return) wire--they use up what is available on demand in heating elements or in welders - the electromagnetic field.GET HELP DOING THIS, by someone who has knowledge, SKILLS and EXPERIECE. I have 1 welder fitted to go into dryer plug which has 14-30 recepticle, and i have 1 where i kill stove circuit at panel, unplug stove, plug in 14-50 plug which has a 10-50 recepticle on other end, plug in welder 10-50 -p, flip cicuit breaker switch to on-welder has full power range capacity. No oven in use while welder going--but probably wouldnt run it anyway if on different circuit.Any doubts whatsoever--anything not 100% clear--DO NOT DO THIS or any other Electrical Manipulations--have a licensed electrician stub in a secondary circuit breaker off your main if load is acceptible and have him wire in the recepticle which your plug will fit into---.
May 31, 2012 | Craftsman Welding Tools
How to change oven coil
Unplug the stove. Be sure to kill power to the oven because one wire to the element is hot and comes straight off L2 the power cord. You could seriously injure yourself or destroy the new part by leaving the range plugged in while you replace this element. Tip: pull out the bottom drawer and you will be able to see the power cord and receptacle in most cases and you can unplug the stove without having to move it. When you have the power removed you only need to remove 2 screws and gently pull the element towards you have the new element sitting on the oven so you can add a wire to it as you remove it from the old one so you won't loose a wire through the back. That is how I do it.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back. - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Stove oven wont work..
Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
Hope this help you! :)
Apr 11, 2009 | Viking Stove/Oven/Range Timer Knob -...
Oven and broiler won't come on
It's most likely the igniters in the oven. They cost about 40$ apiece and our oven has two. They are fairly easy to replace.
1) Turn off the electricity to the stove, either with a switch or your circuit breaker.
2) Remove grills, side support grills and oven base. They all just slide out.
3) Remove door to avoid breaking it. It slides off.
4) Remove old igniters, they are attached with two screws. Remove 2 wires from plugs. It might be necessary to lower the front base panel to get to the plugs - the panel is attached by two screws on the side of the panel.
5) Install new igniters, put the door and grills on and you're good to go.
The first time, it might take an hour to get used to your stove, but its really about 15 minutes of work.
Jan 13, 2009 | Viking VGSC306-4B Gas Kitchen Range
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Kitchen Ranges Logo
177 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
