Question about Tecnik TKL9260 Front Load Washer
Machine not spinning.
Just noticed that the cycle on my Tecnik 9290 was not behaving as expected. The load was sitting in the drum full of water but there was no spinning. I emptied the machine and drained out the water. Put the machine on spin and I can hear the motor kick in and run but the drum isnt rotating.
I assume that the belt is broken? How easy for this to be replaced?
Thanks
  • 43 Answers
If its the motor you can hear the belts probably fell off but you may have mistaken the motor noise for the pump so if the belts on check the pump filter
Posted on Nov 10, 2008
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
DOOR
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
also...
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
How do I get parts for my tkl 9290
You might start here: Tecnik Washing Machine Parts
Be forewarned, your washer has a LOT of discontinued parts.
Oct 24, 2014 | Tecnik TKL9260 Front Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Spin only on Tecnik TKL 9290
Prog 7 is cotton and linen cycle spin.
Prog 17 is delicates spin.
There is also a button to select fast or not so fast spin.
Sorry cannot help with online manual.
Sep 14, 2008 | Tecnik TKL9290 Front Load Washer / Dryer
Tecnik 9290 washer dryer
Check for a low vent air flow,...Try removing the vent hose for just one dry and see if you correct any problem here.
May 01, 2008 | Tecnik TKL9260 Front Load Washer
Tecnik TKL 9290 / Washer Dryer
no drain then no spin check the filter and also if there is a foreign object jamming the drain pump impellor
Jun 16, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
Tecnik TKL9260 Front Load Washer Logo
220 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
