Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Maytag quiet plus II - leaking water
I have a leak but dont know where from. Its definitely not the water in and I suspect it may be the drain but when I looked usisg a flashlight I didn't see any signs. Just a little too far to get my hand and arm in through the back.Are ther other reasons why the machine might leak?
  • Jinxme Dec 20, 2008
    Same problem but I want to know how to get inside to adjust the drain hose besides that tiny hole in the back of the washer. Is there another way to gain access to the drain hose screw clamp????
1 Water pump will always leak on shaft seal. Seals no longer available and must by pump and motor.
Main shaft seal will leak and then rust hidden main bearing. This is BIG problem but not unfixable. 2 Maytag OEM tools required to dissassemble and shitload of parts.
Maytag service guy charged me $120 for 20second look then walked on me as he said it was too hard work. He was right but I'm the bunny that dropped 2 grand on a washing machine 2 days out of warrenty so I fixed myself,
Posted on Feb 09, 2009
  • 95 Answers
Check under while the washer is filling and draining. You could have a loose clamp on a hose, the seal on the shaft may only leak while doing these. On the other hand, more times than not, rodents seem to enjoy chewing on washer catch basins.
Posted on Jul 06, 2008
I just bought a used Kenmore Elite quiet pak II washing machine. It works great except that it doesn't desperate the liquid softener that well and it leaks from underneath when it pumps the water from the...
softener tends to clog up the input tube-leaking in front may be the door seal-also check the drain trapinside the little door on the bottom-cheers Denny
Oct 31, 2013 | Washing Machines
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking during rinse cycle
If your TOP LOADING Whirlpool washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 05, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking water on bottom left side ...water to ice maker is shut off in basement...still leaking
check the water drain is not plugged...you may need to take the inside back panel off if you have water on the floor see if the drain hose is in the tray under the fridge
Aug 07, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a Whirlpool Ultimate Care II washing machine that is leaking water onto the floor. The water is not coming from the back of the machine. What do I need to look for and how do I get into the machine?...
I suspect you may have a drain pump leaking on your washer. The following link explains all the steps necessary to access and/or replace the pump (if required):
http://www.fixya.com/support/r397092-replacing_water_pump
If the leak isn't too bad, allow the tub to fill about 1/3 of the way and turn off and unplug. With the exterior case removed, you should be able to see where the leak is coming from. If the leak is coming from the front of the washer, its probably your drain pump or drain hoses. If the leak is coming from the center under the wash tub, you more than likely have a bad tub seal. If the leak is coming from the side of the wash tub, you probably have a loose air hose on the air dome (with this problem, the washer will begin to leak when the tub gets to about 1/4 full). Also check all your drain hose clamps to ensure they are tight. The only other thing that can cause leaks is a cracked wash tub (not real common).
If you have questions, please let me know. I hope this helps you narrow down your problem.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 200 Dishwasher Leaking Internally
two possible sources of water
either
inlet valve leaking. turn water off after use and if no water accumulates, then cause is leaking valve
or
if drain is plumbed in to a spigot on the sink trap, then every time you empty water from the sink, some of it goes down to the washer
cure by taking the drain hose up as far as possible under the sink in a swan neck
Oct 12, 2008 | Maytag Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
582 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
