Symbol MC50 Pocket PC Logo
Posted on Jun 29, 2008
MC50 won't boot with battery attached
I have 2 MC 50s. Both hardly used, but about 2 yrs old. Neither will boot with battery installed. Both will boot in cradle with battery removed. Both batteries will charge in cradle as stand-alone. Initially, both batteries would not charge in MC50 when dead. Once batteries were charged, they would show in MC50 as charged when in cradle. However even with charged batteries in MC50, in or out of cradle, they won't turn on.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
548
Points
Be sure the Battery is in the "LOCKED" position, with the lever all the way to the right.
2helpful
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Suddenly screen ceased to respond samsung gt s5560 sparingly used 2 yrs old
Try removing the battery while the phone is still on. Wait a few seconds and put back the battery once the phone boots up, you should be able to use the touch screen. Recalibrate the phone and that should take care of it.
1helpful
Sierra wireless 881 - 2 yrs old - after a short time on line needs to be re-booted to continue downloads, or even find the web site.
test the lead/s make sure they have secure connections and are not faulty whether usb or ethernet you might check your modem first to make sure that you are getting a connection
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
6helpful
Motorola MC-9090 HARD RESET PROCESS
To Cold boot MC9090 do the following.
1, Partially drop the battery to the half way stage.
2, Pull the trigger and press the power button in at the same time for 10 seconds.
3, the device will now boot to it's originally state.
Anything stored in temporary memory will be lost with this process.
The Fetcher
Symbol MC50 battery power problem
you need to check your power management settings, idle / standby as it sounds like your terminal is just "on" all the time
1helpful
After reset MC50
try hard reset... 1+9+power button
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
