Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
Hi my fujitsu inverter AR-Ry3 is stuck on a timer how do i remove this?
There will be symbol CLOCK press for 5 seconds. 12.00 or 00.00 will be blinkering. Use up and down buttonn( > or > ) to set your required time. Thanks.
SOURCE: my fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
