Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Maxtor OneTouch 500gb external; delayed wri...
By chrisw23 on Jun 29, 2008
My new Maxtor OneTouch 500gb external USB worked fine for about a month. One day--and ever since--I went to disconnect it using "safely remove hardware" as I always do, and I got an "$mft" error accompanied by a "delayed write failure" notification. Looking in event viewer, I saw Event ID 50 (delayed write failed), which indicates the data was lost because Windows was unable to save all the data. This was accompanied by Event ID 51 (error detected on harddisk during paging operation), and Event ID 57 (system failed to flush data to transaction log, corruption may occur). Seagate somewhat addresses the $mft/delayed write failure issue with no real solution. I've also run Seagate Tools and everything passes. The external seems to be working fine, I'm still able to load all my files, which is primarily music, and the files are fine (although I know I'm probably playing with fire by continuing to use it until this is resolved). But every time I go to disconnect the external now, the same thing happens, along with the message that says "generic volume cannot be stopped; try again later," because "some other program is accessing it right now." But then, if I shut down the computer and reboot it, it lets me disconnect the external using "remove hardware safely." The external came with a six-pin firewire, and my computer has a four-pin port. So I haven't tried that or a different USB cable yet. Any input on this would be greatly appreciated.
Same Problem
May 10, 2009
-   I get the same "write delayed error" problem. I have a Maxtor 750G OneTouch 4 Plus. Any tips from anyone please? -   Guest
Jan 29, 2009
-   when ever i fix my external 500gb hard disk it starts working fine but then it will freeze and wont eject which later write F:/Mft or write delayed.......saved data could be lost-   ket_ketank
Nov 25, 2008
-   when ever i fix my external 80gb hard disk it starts working fine but then it will freeze and wont eject which later write F:/Mft or write delayed.......saved data could be lost-   Bash2kool
Jul 28, 2008
-   I have got accurately the same problem but not on exactly the same type of disk. The disk I have is a 300GByte One Touch II .
I have re-formatted the disk and still the problem appears after just some days.
I tried to do a chkdsk including options /F /V /X /R but there is no direct access to the drive once the Master File Table is not accessible.
Any input would be greatly appreciated.
Best wishes,
Johannes Helm
Univ. of Oslo
Dept. of Anatomy
P.O.B. 1105 - Blindern
NO-0317 Oslo
Norway-   Guest
Solution #1
posted on Aug 09, 2009
Somewhat Helpful)
DrunkenMonk
Rank: Guide
Rating: 75%, 1 votes
1) Always make sure your system is clean of viruses and use scandisk to check the file system's integrity - no point making changes to a system based on corrupt files, as things will likely stay corrupt. Try scanning the registry too with your favourite registry scanner.
2) Use a program like Sysinternals (Winternals now under Microsoft) ProcessExplorer. If a process really IS using the USB drive, then you can do a search for exactly what is being used by searching for "<DRIVE LETTER>:" and interpreting the results. Malware could be using it or just a program you were running hasn't correctly 'signed-off'. You can force-close the offending item if nothing else works. Then the drive should allow itself to be safely removed.
3) Check your USB chipset drivers. Install any updates available, or if none are, then uninstall & reboot, then re-test.
4) Power is the baseline for everything electronic, people forget this too often. If you can, check the PSU (an external one I assume with this model of drive) with a multimeter.
5) Try on another PC (preferably with the same OS) at length.
6) Try with a different USB cable.
7) Try with the Firewire cable as a workaround (the hardware/chipset used is different, so likely to encounter different hardware/software issues, but interesting to check if any similarities).
GOOD LUCK - I hate USB, it's so fiddly with all the different driver/chipset/hardware implementations that it can be a nightmare to troubleshoot.
Comments:
Aug 09, 2009
- (This is for anyone with a similar problem, basically, as this is over 12 months old).
Was this helpful?
Yes
No
Solution #2
posted on Jun 29, 2008
Somewhat Helpful)
WebMAAC
Rank: Apprentice
Rating: 58%, 2 votes
* Mac OS: la función VD Video no es compatible a través de VOB/IFO (carpeta Video_TS). El tamaño de archivo DVD ISO no puede superar los 4 GB. El sistema de archivos FAT32 / MS-DOS no admite tamaños de archivo mayores que 4 GB. No intente formatear la unidad en el sistema de archivos HFS+, ya que no es compatible en el modo TV.
Comments:
Jun 29, 2008
- * Mac OS: DVD Video function is supported via VOB / IFO (Video_TS folder). DVD ISO file size cannot exceed more than 4GB. FAT32 / MS-DOS file system does not support files size higher than 4GB. Do not try to format in HFS+ file system as it is not supported in TV mode.
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
Hi there, my computer will not boot up, I get an error message "Sec Master Bad, Back Up... (More)
Answer
It will only see a portion drive is 1.5 It sees 137
Answer
Book does not boot up, it seems to try, makes a clicking sound, and then shuts down
Answer
after 3 weeks of working fine my transcend storejet 25m 500gb is still supplied with power via usb... (More)
Answer
jh8408 PEC board burnt out where can I get a replacement
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hard Drives:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
