I have a Philips Projection Tv. The color is not right. It is to pink and you can't ajust it.It doesn't look like it has any black. It is only 5 years old
Uygy
hkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkhhhhhhhhhhhhhhjjjjjjhgguuukkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Posted on Jun 29, 2008
Uygy
Uygy
Uygy
  • 8,617 Answers
Sounds like the coolant needs to be changed in the CRts. You can get a CD with complete Instructions to change the coolant yourself at the following link that has step by step instructions with pictures. Its listed under the repair kit catagory on the left side they have the CD available or you can get the complete repair kit which includes the CD and 48 ounces of high grade optical coolant. Heres the link.
http://servicemanuals.vstore.ca/
Want to change the convergence chip in my philips projection tv model#51pw9363/17f
Has a projector tv model 50p8341 philips that has a pink color to it work fine but the color, has a new board in it going to throw it in the trash is 10 years old if you no anybody that need parts let me know. no one can tell me what is wrong . would you no?
Feb 19, 2013 | Philips Televison & Video
Color projection tv
Adjust the top left knob back down till the color comes back
Feb 25, 2010 | Philips Televison & Video
I need to know how to ajust the color on 6p5430w102
Tries all factory reset for colors.Than reduce the colors bar foreless should look good,for the tv set.
Nov 26, 2009 | Philips 6P5430W 54" Rear Projection...
On my Phillips rear projection tv. The blue mulitipoint ajustment is not working. It will adjust left and right, but not up and down.
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 60PP9202 60" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
My Philips 51PW9363 has pink and green colors only!!!!
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 05, 2009 | Philips 51PP9200D Television
Color alinment
Replace your STKs big black ics 392-020 go to 040s if they are 110s,150s go to 180s.
Oct 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Can i fix it myself/ phillips/magonavox 60 inch tv big screen
When you turn the color all the way off do you get a black and white picture? If not you will need to do a grayscale adjustment. Turn the brightness and contrast down until you get a black screen. Then advance the screen control on each CRT until it just lights the screen and then back it off to just black. If one of the colors does not appear then you can adjust the master screen (usually on the HVT) and then readjust the other two. If this doesn't help you can try to clean the projection lens on each CRT. If anyone smokes in your house then it's possible that soot has built up between the lens and the CRT. Separating the lens from the CRT can be complicated and even dangerous. I would have a TV shop check each CRT and see what they recommend. This can be done in your home. Good luck.
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips 52" big screen is looking blurry. Can I tune it myself?
my projection tv color is red I have tried ajusting the color but nothing the pic is still to red
Jul 07, 2008 | Philips 55P8341 55" Rear Projection...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
