Question about Apple (661-2795) for iMac Motherboard
Imac motherboard following electrical storm, motherboard failed. os 9.2/10.3 locks up at boot. no evident damage. any suggestions?
  • 3 Answers
Hack the setup procedure and create a new admin. Here is the link to show you how.
http://www.ihackintosh.com/2009/05/how-to-hack-the-user-password-in-mac-os-x-without-an-os-x-cd/
Posted on Sep 16, 2012
I have a aple imac and i forget the admin password and i cand log me in
can you help me
Posted on Sep 24, 2008
Apple imac with no operating system
Hard drive may be bad or installer disk has scratches. Replace hard drive and disk and try again.
Jan 20, 2013 | Apple iMac G5 Desktop
My Imac (MA877LL) was on during a lightning storm. After li9ghtning stuck close to my home, my computer flash and went off. There were other mnor problems with other electronics at the sameutton time and...
1.Unplug all cables from the computer, including the power cord.
2.Wait 10 seconds.
3.Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
4.Let go of the power button.
5.Press the power button once more to start up your iMac
Visit the link below:
http://support.apple.com/kb/ts1367 and follow the troubleshooting steps.
Jun 23, 2011 | Apple iMac 20" MA877LL Desktop
IMac OS 9.2 hangs up in the "starting up" mode and
You may have a problem with your internal hard drive.
If you have your original software disks, you can boot the computer from them and run Disk Tools to analyze and possibly correct any problems.
Mar 01, 2011 | Apple Mac OS 8.5 (APPLEOS85)
Operating system fail to install
My dear friend you've not mentioned what exactly the problem you are facing please be specific if you can. Basically the operating system fails to install because of the following reasons
1. OS CD Damaged / corrupted.
2. Disk Drive Corrupted.
3. Some files of OS in the CD got corrupted/damaged.
4. Your hard disk master boot record got damaged.
5. Your motherboard got damaged.
Hope i was able to solve your problem.
Sep 13, 2010 | Microsoft Windows XP Professional
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
IMac G4 17" Flat Panel 1Ghz, new PSU, boots to Gray
Sounds like possibly the motherboard has thrown in the towel.
1 thing to check is did you apply new thermal paste to the processor before putting motherboard back in?
Did you make sure all wires were seated as you pushed motherboard back in?
Apr 18, 2010 | Apple iMac G4 Desktop
Takes a really long time to boot up , locks up when any program is opened
Three major possibilities: corrupt OS, failing drive, failing logic board.
There are many ways to diagnose this, but each requires equipment or packages an average user may not have. You could boot from a DiskWarrior CD and run a disk rebuild; this would report disk hardware failures. You could boot from an external drive containing a bootable copy of the OS; if it still boots slowly and locks up, the logic board is suspect. You could reinstall your OS using archive-and-install; if this fixes the problem, it was a corrupt OS.
Sep 12, 2009 | Apple iMac G4 Desktop
IMac G3 unable to boot up
OSX isn't compatible with the older G3's.
Mar 26, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
IMac 266 Rage Pro Won't Boot
I don't think the installer will work over a network. I think you need an actual CD of 8.5/8.6 or an external drive with the OS on it.
Dec 30, 2007 | Apple iMac RAGE PRO/233/266/333mhz Logic...
Blue iMac
It sounds like there's underlying problems unrelated to Panther. If the computer boots from the the old HD, but then the HD didn't show under Disk Utility, this is an intermittent problem. Try replacing the cable that goes to the HD (if there is one), it may have become damaged sufficiently that things aren't working under "heavy use" (like trying to install an OS). If there is no cable, or replacing it doesn't work, I'd suggest putting the original HD in and selling the computer as-is. Again, if it still botos from the old HD, then it's not a problem with the HD or Panther, unless the reconditioned HD you bought was faulty (unlikely but possible). More likely is when you installed the reconditioned HD, something else changes (e.g. connection made better contact) that caused the HD to show.
Sep 10, 2007 | Apple (661-2795) for iMac Motherboard
Apple (661-2795) for iMac Motherboard Logo
284 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
