Question about Euro-Pro 373 Mechanical Sewing Machine
Euro Pro 373om sewing machine
The feed dogs aren't working. I've had the face plate off, cleaned everything under & over the feed dogs, rethreaded the the machine, including the bobbin, nothing works. Any solutions?
  • 46 Answers
If you have checked the feed dog switch, best to take it to a sewing machine mechanic.
Posted on Oct 24, 2008
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
https://www.youtube.com/watch?v=QndkRbDfM2w
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ...
Amazon.com: Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
My euro-pro shark 8260 machine is stuck, even hand wheel does not move. can you please tell me how can i fix it?
Have you taken out the sewing plate and removed the feed dogs? Sometimes a huge knot of thread can get under there which disables the machine.
Best wishes
Aug 28, 2014 | Euro-Pro Sewing Machines
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Mar 15, 2014 | Euro-Pro Shark 60 - 384
Reverse button broken
the reverse button that makes the machine sew in reverse is not the feed dog, the feed dog is in the needle plate area. under the needle
when the reverse button is broken the machine must be taken apart and another put in it's place, at a sewing machine repair shop.
Mar 04, 2014 | Euro-Pro Sewing Machines
I need a replacement feed dog and a striker plate for the Euro Pro Deluxe Denim Sewing machine model 1262D
here are 3 sites to email about the parts you need
sewingpartsonline.com
sewvacdoctor.com
a1sewingmachines.com
Aug 03, 2012 | Euro-Pro Sewing Machines
Elma Pro Quilting Queen, I keep getting loops on the bottom. I have rethreaded, reinserted the bobbin and it keeps doing it.
change the needle
clean under the needle plate where the feed dogs are for lint
also clean in bobbin area for lint & loose threads
rethread the machine make sure to get every thread guide
check the thread tension usually 3 or 4
Nov 22, 2010 | Elna 7200 Computerized Sewing Machine
The dog feed stuck in the downward position.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Feb 19, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I have a Euro-Pro 473 model sewing machine, I?m converting into a Needle Felting Machine (adapter is Around metal with seven needles around it and is suppose to be attached into needle bar). I?ve removed...
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
Apr 27, 2009 | Euro-Pro 473
Euro-Pro 373 Mechanical Sewing Machine Logo
115 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
