Question about Jetway V266B Motherboard
2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
Hello, I tried upgrading to 2 x 1GB DDR Samsung PC 2100 266Mhz DIMMs (from 2 x 256MB SIMMs), but both the BIOS and Windows see only 2 x 512MB.
Before buying the new memory I tried 2 x 512MB Samsung DIMMs and all worked well.
The MoBo manual says that it can take 2GB.
Is there a solution for this, or is it just that the memory is incompatible?
Here are some specs for the new RAM
  • 184 PIN Memory
  • 3.2 GB/sec
  • 266Mhz
  • 2.5 Volt Module
  • Non-ECC, Non-Parity
  • Unbuffered
Thank You for your help,
Patrick J.
  • Patrickjh Jul 02, 2008
    Hello Mike,
    Thanks for your quick response.
    If you cannot run more than 512MB in any DIMM slot,(which seems to be the case) and there are only two 184 pin DIMM slots, how is it possible to run 4 x 512MB?
    The other  two slots are 168 pin SIMM slots and will not accept DIMMs.
    I'm still confused.
    It seems that the information given in the Manual is unreliable! The information given in the table on page 10 seems to say that the limit in any slot is 512MB. Yet it clearly states that up to 2GB can be used.
    The Manual also refers to  Bank 0,1 (DDR1)and Bank 2,3 (DDR2)
    Is there a difference between a "Bank" and a "Slot"?
    On the other hand, the 2GB max. is repeated on many website and there is no reference to a problem.
    Perhaps there is something about DDR DIMMs that I am misunderstanding.
    Can you offer any further clarification.
  • 2,351 Answers
Hi Patrick,
I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
So you can not run 1GB of memory in any bank.
Posted on Jun 29, 2008
  • Mike Peluso
    Mike Peluso Jul 03, 2008
    Every way I look at this it just seems wrong. Rather than sending you away (Not how I want this to go). Let me send you to a fried of mine here. Find, Benimur & click his ask me button.
    Or just click here:
    I have a lot of faith in Benimur & he's a great guy. It's ok to mention I'm sending you to him. I just want you to have the best shot at getting this right. (Vote's mean very little if I am stumped & you do not get a decent answer that make's sense).
Trying to help a buddy upgrade his gateway esx 500s memory as he only has 256mb, is there a limit to how much mem this comp can take or can i install 2GB 2x1GB PC2100 ECC REG MEMORY (CM12872ERX22100DI
Hi Steve Handel II,
Yes that machine has limited RAM capacity, that model can go up to 1GB of RAM total (2x512MB DIMMs.) It takes DDR PC2700, CL=2.5 unbuffered, non-ECC DDR333 memory chips. The good news is you can get them for $10-$20 most anywhere. Like HERE
Good Luck
May 11, 2012 | Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Why won't MB recognise new 2 x 1Gb Memory?
The motherboard does not support 1 GB modules; 512 MB is the maximum the motherboard will recognize. Usually, the computer won't even work if the memory isn't supported but in this case it does.
Thanks and please remember to give this a thumbs up rating.
Apr 26, 2009 | MSI MS-6390 (-6390-010) Motherboard
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
Apr 24, 2009 | Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Jetway MoBo: 2 x 1GB Samsung PC2100 appearing as just 1GB (2 X512MB)
Your post indicating that you are moving up from SDRAM to DDRAM shows that your motherboard is capable of either type (having both type of slots) and therefore would have been a few years old. Having said this, then your MB would have the very early version/compatibility of DDRAMs where/when 512 then was the highest readily available memory.
As most Taiwan manufacturers, Jetway would be publishing specs that are a bit just over rated in terms of their product performance unlike Asus, ABit, AOpen. Additionally, most have been known to be using the same manual for several versions of the motherboard. A similar looking motherboard can come in several versions such as those with internal video while another is an AGP slot; one versions may or may not have built-in Ethernet port. In the same token, a version may have 2 X SDRAM slots + 2 DDRAM slots or 4 X SDRAMs or 4 X DDRAMs. Again, we are talking of the same model number of the motherboard but different versions/revisions.
2 G would be right for the 4 X memory slots versions (at 4 X 512) but since you have the 2 + 2 (2 SDRAM + 2 DDRAM), maximum would only be 1 Gb (2 X 512).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 03, 2008 | Jetway V266B Motherboard
Choosing/upgrading DDR memory
hi there,
i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Critical after DDR333 upgrade
I got your latest version (8.1) motherboard on my screen & ECS shows your board does not support PC2700, only PC2100.
Downloaded your manual to verify this.
Notice you started having problems after upgrading RAM.
Link to your manual:
This motherboard accommodates two 184-pin DDR DIMM
sockets for up to 1GB memory. Supports PC2100/PC1600
unbuffered non-ECC DDR DIMMs.|c:147|&Sort=0&Recs=10
Good Luck!
Mar 18, 2008 | EliteGroup P4VMM2 Motherboard
Jetway V266B Motherboard Logo
154 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
