Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio EX-z600 6.0
I try to take picture and green light flashes and does not take picture
Please reply my problem
Posted on Oct 13, 2008
Presently charging my camera, does the red light alway blink?
Base on User's Guide of Casio Exilim EX-S600 Digital Camera, Flashing red light when charging the battery is mean "charge error"
(see the picture)
to overcome some problems that may occur, please refer to the User's Guide of Casio Exilim EX-S600 Digital Camera which can be read here:
http://support.casio.com/pdf/001/EXS600_e.pdf
good luck :)
Apr 17, 2010 | Casio Exilim EX-S600 Digital Camera
Dropped camera CASIO EX-Z1050
Try to resset settings on MENY
or Take a look this manual
HERE
OR
Here
Mar 24, 2008 | Casio EXILIM ZOOM EX-Z600 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim z75 - unable to take pictures
Try shutting off your flash and see if it still does that. It sounds like you have a problem with your flash not charging correctly. You can try resetting the camera but I doubt if that will help. I would try just shutting the flash off and see if that would help.
Aug 26, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio exilim ex-z70
Sounds like ccd issue. Some people have reported similar problems when cam is exposed to water (moisture) or if it's been dropped. Contact you local Casio service and ask them details. They probably just say that send the cam to repair but that is expensive, at least in here Europe.
Jul 22, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
CASIO EXP600 Flash problem
Hi, I sent my camera to the dealer...thanks anyway, Sevendata
Apr 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Red light continually flashes, and won't take picture
I have seen this problem on the ex-s880 casio camera a few times sometimes you can go into the setup menu and reset the camera to default and that some times fixes it. it that does not work I have had to replace the flash circuit on the camera because the large compasitor is out and needs tobe replaces most likely this is your problem because of the flashing LED. Hope this helps its a great camera also you might want to check with casio because this should be covered under warrenty. If the camera was not dropped.
Mar 28, 2008 | Casio Exilim EX-S600 Digital Camera
Casio EX-Z57
Try playing with the background or lighting - ex: take pics during the day versus nite... use a white/light colored background versus something dark.
Make sure you have the flash set to "auto" or try the "red eye" setting.. I've had good luck with both of those.
Also make use of the zoom. Stand farther back and zoom in - versus being close up and NOT using the zoom.
Hope this helps :)
Mar 02, 2008 | Casio Exilim EX-Z57 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Flash problems, Casio Ex-z3
Try resetting your camera. Sometimes it is just an issue with the flash charging. In rec mode press menu go to setup tab go up to reset press right arrow highlight reset press set If that doesn't work then u will have to send it in. :)
Sep 04, 2006 | Casio Exilim EX-Z3 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
55 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
