Question about Refrigerators
We have a side by side maytag plus refridgerator freezer that has frost on and behind the back panel of the inside of the freezer. Everyting started to thaw. This happened to us before and we were told that there wasnt proper circulation in the freeze. We have thrown everything away and emptied both fridge and freezer but I can't remember how the problem was corrected. Can we just unplug the appliance and wait for it to thaw and dry out and start all over again?
  • 828 Answers
Unplugging and letting it completely thaw out is not the answer to your problem in the long run. You have a problem in the defrost system. These problems are normally cause by the following; The defrost timing device has failed. If it is a timer it can normally be located near the temperature control area. It will have a hole in the plastic cover through which you can access the clutch head screw. Turn the screw Clockwise very SLOWLY until you hear one audible click. that will put the system into the defrost mode. Wait about 25 minutes and the defrost of the freezer coil should happen. If the system does not restart and defrost happens, turn the timer again one audible click and the system will restart cooling. (Replace the timer). If the system restarts after the time period and defrost does not take place your problem is in the heater or defrost thermostat. Back wall must be removed inside the freezer to access these components.
Posted on Jun 29, 2008
Maytag model MSD2351HEQ freezer side is not working, refridgerator is cold
f1cdedb3-5e7c-47c1-8d68-7566d4da0a75.jpgSounds to me you may have a defrost failure. In most cases the fresh food compartment will show signs first but your model has an auto damper that may be causing the fresh food section to remain cold. Do you notice frost build up on the rear inside back panel of the freezer? Example HERE. If you do you will need to manually defrost the freezer, remove the rear panel of the freezer and use a hair dryer to melt the ice covering the evaporator coils. Example of ice/frost build up on the evaporator coils HERE The most likely cause for the problem is a defective=> 12002495 Defrost Control Board The defrost board is found inside the fresh food section and inside the control panel. Item 12 in this photo HERE is the defrost control board. Second possibility is the=> 67004948 Defrost Heater Item 7 in photo HERE and is the 67004757 Defrost Thermostat and that item location 3 HERE First the defrost control board needs to be checked for burn marks or signs of heat damage. I am here if you would like me to help you get to the parts I listed above, Thanks Sea Breeze
Aug 09, 2013 | Maytag Refrigerators
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
FRS26KR4CB1 side by side refridgerator
Hi MDstuff,
Stopped cooling.  Check the backl of the freezer to see if the Coils are Frosted completely.  The buzzing sound could be the frost touching the  Fan in the back of the freezer behind the cover. Sounds like your Defrost heater has gone south.
1. unplug the Freezer, power down.. for safety
2. Clean all the food out of your Freezer,
3. Remove the shelves and Ice maker tray stuff.
4. REmove the panel in the back of your freezer
5. Is the Coil(Evaporator, Radiator)you see  frosted up?
6. At the bottom of this coil. you should see a metal assembly that stretches accros the bottom of the coil with a wire connection on both ends. This is the Defrost heater.
Remove the heater and look to see if the heaterspring inside the glass tube is broken.  If so, get a new one from Ebay, or www.repairclinic.com.
In the mean time while your waiting on a part, Use a hair dryer to get rid of all the frost and put your freezer back topgether.  You sahoul get 2 or 3 weeks of service on your Freezer, before it happens again.
Oct 13, 2007 | Refrigerators
I have a Maytag plus side by side refridgerator-freezer. The freezer works properly, but the refridgerator temperature is to high.
While you look into the back of the freezer compartment to look for ice or snow collecting on the back panel of the freezer. Let me know what model you have and I will be able to help you with part numbers what you need to do next. Let me know the model number listed most likely in these places, Thanks Sea Breeze
Jul 20, 2009 | Refrigerators
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refridgerator too warm freezer ok running constantly
could be your evaporator fan which is located in freezer.If you dont hear it blowing when compressor is running then it is evap. fan motor.if you see alot of frost building up on back panel inside freezer then you have a defrost problem.check heater and thermostat to see if they are good or bad.the thermostat will usually pop apart but not always it is located at the top in back of freezer on coils.it will have two wires going to it.good luck.and unplug first.
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Need help on Maytag Plus Ref
First check for a thick frost buildup on the back panel of the freezer at the bottom.  Also, check to see if the fan in the freezer is running.  Let me know what you find so I can lead you in the right direction.
Oct 18, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
