Question about Salton Clarity
SALTON MINI HEATER MODEL NO,SGH10
Bought the above mentioned product end of last winter. We have a problem lighting the gas heater the first few times it lite okay the one panel is not burning as good as the other one, then when we wanted to light it again it would not light it is as if the gas is not going through to the burners. Is it possible that you have an answer for us
Regards
Anina Dyer
email: aninadyer@telkomsa.net
2 Suggested Answers
SOURCE: Salton ice cream maker manual
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from kitchen.manualsonline.com
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Posted on Aug 18, 2009
How do you winterized a pent air mini max nt pool heater
make sure antifreeze goes in the in and some comes out the out then turn off gas and pull drain plugs
Oct 05, 2015 | Mini Pool & Spa
How Do I restart the rheem 81v30d
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Rheem does not post service manuals.
One reason is that water heaters have changed rapidly last few years, and same model might have different features because Rheem experiments to see which products work after they are sold.
Calls to Rheem for DIY help are largely useless since they want you to call local installer or technician... who will sell you a new heater for more money.
Rheem wants to end DIY repairs since doing it yourself saves you money... which means Rheem, and Rheem-loyal service companies make less money.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
http://waterheatertimer.org/New-government-water-heater-standards.html
Gene
New government water heater standards
Feb 12, 2015 | Rheem Water Heaters
My utilitech space heater will not power on. i just bought it end of last winter so have not used it much
Hi Beth, is this electric or gas? It makes a big difference which.
If you bought it new there should be a warranty. Consider taking it back if you can.
Oct 27, 2014 | Heating & Cooling
Teledyne lars heater, pilot is on but wont fire up, whats wrong?
Somewhere in your "safety loop" something is open. Like old fashioned Christmas lights if one light goes out the whole circuit dies. Instead of bulbs you have a fusable link (rollout sensor), a pressure sensor, the on/off switch , the thermostat(s), and two high limit switches.
The fist thing is to clean/backwash the filter to make sure it's not simply low pressure causing the heater not to fire. If that is okay the problem may lie in any one ore more of the switches and sensors mentioned. The gas valve itself may also be the cause.
Sep 05, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Charmglow ventless lp gas fireplace model CGL300TQ pilot light wont stay lit, how do i know if its thermocouple or regulator?
if the therocouple has packed up pilot light will not light thermocouple has long small diameter pipe leading to a larger end this needs to be above the pilot flame also for safety have a small bowl of soapy water with a brush wet the nut with soapy water in no bubbles appear then try lighting heater thermocouples don't last that long
Jan 26, 2013 | Rheem 36" Water Heater Thermocouple Kit
I have a Rinnai Avenger 25 gas heater. We turned power and gas off after last winter, now we cannot get it to light. It will light for roughly 10 secs and then goes out. There are no numbers set in timer.
Since the gas has been OFF since last Winter, I suspect that there is air in the gas line that needs to be purged. In addition, if it has not been cleaned and serviced annually, the pilot and the burners need to be cleaned. Spiders & other insects love to build nest in them while they are off. Not to mention, accumulated dust. Unplug the unit before attempting any service work.
Purging and cleaning should solve your problem.
Apr 12, 2011 | Heating & Cooling
It clicks & i can see it spark, but it won't light. I don't smell gas at all & the gas valve is open. At the end of winter last year it stopped lighting & I stopped using it. Do I need a...
I would say that the pilot assembly be removed and cleaned thouroughly. If you can't get it to working properly than I would replace it.Hope this helps, Thanks
Nov 20, 2010 | Vanguard International VN30B Infra-Red...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Forsaire by Williams Model 455 FEI, will spark but does not light
i had this problem a couple years ago and I had to scape where the flame lights and reset at the fuse box and it worked good luck
Jan 08, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Salton Clarity Logo
280 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
