I want to upgrade Ram
I want to upgrade the ram but i see so many types DDR2 DDR300 i am confused as to what this motherboard will have it's got DDR SDram in it right now I have a W2060 Emachines what can i do to upgrade it.
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Upgrading your computer can be a complicated task, as there are lots of different types of memory available. Luckily there are means to make it much easier.
What i would suggest is clicking here and running the memory scan, it will tell you what memory you have exactly already and let you know which new memory is compatible and best suited for this system.
I have purchased and used crucial memory for a lot time, it has free delivery and lifetime warranty. If you do not want to buy it online, print out the page it shows you and take that into your local store, they will be able to choose similar memory.
Hope this helps.
Posted on Jun 29, 2008
I have P4 2.66Ghz processor, D101GGC motherboard, but this motherboard support DDR RAM, so I want to upgrade my Motherboard which support DDR2 RAM, please help me
This motherboard only Support DDR RAM.
It will not support DDR2 RAM.
So, you have to buy a new one.
Thanks for using FixYa.
May 24, 2011 | Computers & Internet
I am owning a AMD Sempron 2400+ desktop.which is having DD ram of 608mb.in 2 slots.( one 512mb and the other 128mb ).When I looked at the board, there are 2 slots only indicating DDR! &DDR2. Now I want...
DDR (or DDR1) and DDR2 modules look similar, but the keying notch is in a different place. This figure shows the two types so you can identify which you currently have:
The type of memory used is determined by the motherboard. The markings on your board are just labels for DDR module 1 and DDR module 2; you will need to check the picture to determine what type memory you need to purchase. I suspect you will need DDR1, since DDR2 is a more recent type. A Sempron system will probably be an older board.
You can find specifications for the type and amount of RAM the motherboard will support at the manufacturer's website. If the computer is a consumer brand such as HP or Dell, go to their website and follow the links to the support and downloads page. If this is a custom or home-built computer, you can get information from the motherboard maker's site.
Mar 29, 2011 | AMD Sempron 2400+, 1.667 GHz...
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Ddr or ddr2??
your RAM memory is not DDR2 It is DDR1 so if you want to upgrade you should buy DDR1 RAM .
Ddr 2 ram connecting to intel d101 motherboard
Well first of all, there is no "adapter".  You have to use the specified RAM that you motherboard supports.  Secondly, even if there was an adapter so to speak, it would not be beneficial.  The only difference performance wise between DDR and DDR2 is speed.  So if your motherboard supports DDR, and you had an "adapter", your motherboard would only read the DDR2 at DDR speed.  In my opinion, DDR2 is not really worth the upgrade to another motherboard just for DDR2.  If you want the biggest bang for your buck, upgrade the CPU, or put more memory in the motherboard you already have.  Hope this helps, and please don't forget to rate.  Thanks.
May 30, 2009 | Intel D101GGC Motherboard
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
Upgrading Ram
Make sure you have the RAM seated in slot #1, and that you do not have DDR RAM installed as well, as DDR2 with DDR RAM will not work. Also, make sure the RAM you bought is on the QVL (Qualified Vendors List) for that motherboard. I know I have had problems with ASUS motherboards and OCZ ram before.
QVL Found HERE
Sep 05, 2008 | ASUS P5VDC-MX Motherboard
yes there are different types of ram available but since u have a ddr 1 type of ram ddr2 wont match in ur maotherboard.and also do try to get the same type of ram available presently so u dont have problem with the clock speed.
May 12, 2008 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
