There will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
Rick
heres the link
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS24SEWH5/0593/0130000?searchedModel=KUDS24SE&blt=
Testimonial: "This was very helpful, would have been even more helpful if I'd had it when I was repairing the dishwasher. Thanks, Jim Rea"
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Daniel
