Question about Haier AHD25 Dehumidifier
Loud buzzing or rattling noise
There has developed a loud buzzing or rattling noise from my dehumidifier. it appears to be the fan motor, part number GE-5ksm84dfk98p. Can I tighten this up or if not, where can I get a replacement motor?
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Dehumidifier started making a loud noise. Is this something we can fix?
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Jul 27, 2015 | Midea Westpointe 50 Pint Dehumidifier
Noise
There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Apr 22, 2014 | Haier 65-Pint Dehumidifier
Bucket rattles loudly and compressor buzzes
Sounds like compressor is having trouble starting not much can be done with dehumidifiers because not many people work on them and they are very cheap to replace. Replace dehumidifier its not worth time and money cut you losses. If this helps please rate me and do a testimonial.
May 21, 2011 | Kenmore 54701 Dehumidifier
My GE 50 pt humidifier works great - except it will not let me set the fan speed to low or medium - it runs on high all the time. I am SUPPOSED to be able to set fan to low.... HELP IT"S TOO LOUD ON...
It sounds to me like you have a defective switch. I would recommend that you contact a G.E. dealer with the model and serial number and describe your problem.I can't find the right file right now but I believe thatthis switch is about twenty dollars.Thank you.
May 14, 2011 | GE AHG40LA Dehumidifier
My dehumidifier is making a very loud noise
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 12, 2010 | Kenmore Dehumidifiers
Loud noise
try to put some lubricant to smooth the work of the fan
Nov 16, 2009 | Danby DDR586R Dehumidifier
Unit is noisy and rattling (70-pint) .....
There is nothing caught in the fan.  I have the same problem.  When taking the back off; unscrew and there our 2 tabs on the to edges about 2 inches in and on the bottom about 2 inches up on each side.  I can't seem to find an answer.   It appears that it could be the motor.  The fan spins freely when I spin it by hand.  I've tried to make adjustments from the fan side.  It looks like I would have to take the condenser coils off to get to the motor  potentially from the front.  Currently, I'm going to live with it because it is in the basement.  It looks like extended warranties are the way to go with dehumidifiers.  My Kenmoore has worked great at pulling water.  The problem has appeared after using a hose set up affecting the drainage.  When I buy another, even though this is my 2nd in 5 years.  But, I am buying the extend warranty this time.   These things break.
May 09, 2009 | Kenmore 54701 Dehumidifier
LGd45el dehumidifier motor cycles on and off
dehumidifier motor making rattle noise
Apr 02, 2009 | LG Dehumidifiers
No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Jun 08, 2007 | LG LD65EL Dehumidifier
Haier AHD25 Dehumidifier Logo
189 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
