Question about Sewing Machines
How to open sewing machine case
Sewing machine applying brake and need to look inside, have cleaned rotary hook and sewing foot
  • 1 more comment
  • shellmar1 Nov 26, 2008
    I cannot get the case off of my Brother XL-2600 to look at the inside. We've pulled all of the screws out and there seems to be something holding it together in the top center of the machine. But there is no way to get to it... the dials on the top hinder the front half from coming off and the back will not come off because of the attachment inside the top.... I'm very frustrated! HELP PLEASE!
  • Anonymous Mar 21, 2014
    Can you tell me the year it was made?
    what year was it made
  • 202 Answers
Possibly thread got caught up where you can't see it either behind the hook or behind the handwheel. Not knowing what model machine you have your just getting generic answers here.
You will have to remove a cover and/or the handwheel to see. Its the only way it could be jamming up unless a gear broke
Good luck
Posted on Jul 31, 2008
  • Rick
    Rick Jul 31, 2008
    Not knowing what model machine you have its hard to describe how to open the case. Remove the screws bottom, top and sides. If its a plastic one it may be snapped togeather and needs to be snapped apart, but if it has to be done it has to be done. I always disliked doing that. Then put it togeather in reverse order.
I need the rotary hook only for a bernina 850 can anyone help me
Fixya does not sell rotary hooks and is not a buying service.
Nov 03, 2016 | Bernina Sewing Machines
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
Sep 23, 2016 | Singer Sewing Machines
Rotary hook machines
Yes it is a rotary machine. The foot you bought may not be the correct one for your machine. Mostly all machines are now horizontal rotary hook machines, but they don't necessarily fit ALL of those machines, it may be for a certain brand of machine.
Best bet is to bring your machine when you buy a foot so you can try it out.
Apr 07, 2014 | Elna Sewing Machines
Industrial sewing machine has jammed, the wheel will not turn
Hello Christine, I think you do have a thread stuck between the rotary hook and the bobbin case carrier. Remove the bobbin case and bobbin. You will need to remove two small slotted head screws and remove the half circle locking ring that holds the bobbin case carrier in place. Try to wiggle the bobbin case carrier one way and than the other until it comes out of the rotary hook assembly. Don't pry too hard or you might damage the carrier and/or rotary hook assembly. Once removed, I think you will find the thread that is causing the lock up situation . Before reassembling, place a drop of oil on the bearing surfaces between the carrier and rotary hook assembly and also between the locking ring and the carrier.
Mar 07, 2014 | Sewing Machines
Needle arm stuck
Firstly, do you pull the fabric as it goes through the machine; this is a surefire way to break needles. Tension imbalance shouldn't be breaking a needle; more likely the thread would break if the top tension is too tight. And botton tension shouldn't need adjusting at all.
It may be that your needle is striking the presser foot if you are applying some "pull" to the fabric at the back of the foot.
But sewing very heavy fabrics is a challenge for many domestic machines - upholstery, heavy denim and canvas is tough going for many machines. Some tough mechanical machines will manage it but many won't. You can try using a roller or walking (even feed) foot as this may help with moving the fabric through but often the feed dogs just can't grip and move the heavy fabric enough. If you need to sew heavy fabrics regularly maybe consider finding a 2nd hand industrial straight stitch machine such as the Singer 20U.
In the case of your Bernettte, remove the needle plate (two screws), pressure foot, stub of needle and bobbin and then search the bobbin rotary hook area and see if there is a piece of needle stuck anywhere, you may need to turn the machine upside down and see if it falls out of the race area. I think this machine has a plastic horizontal bobbin case ??? If so, you will probably find that this has dislodged and may have been struck by the needle so remove it and give it a good visual check for damage, if there is a pierce mark, then give this a file down with an emery board to smoooth it. While it is out, see if the flywheel will now rotate the rotary hook fully.
Then reassemble by putting the bobbin case back in lining up the mark on the case with the stopper in the rotary hook, replacing the needle plate, pressure foot and a new needle.
If you can't get it to unlock at all, then it will need to go to a technician for repair.
Nov 07, 2011 | Bernina Bernette 75
How do i install a bobbin in a toyota rs2000 please
Your machine has a removable bobbin case and vertical rotary hook (front loading) so it is very alike to many other machines in that you insert the bobbin into the bobbin case in a clockwise direction, pull the thread into the tension spring on the case, then place the case into the front of the rotary hook while pulling out the little latch on the case, then release it to secure into the rotary hook. The latch usually goes into the "12" position on the rotary hook, there should be a little indentation for it.
If you go to this page https://sewing.aisin.com.au/upload/1255582851068_file_RS2000SD2D3D.pdf you can download Toyota RS2000 manual and full instructions and drawings are there about page 8.
If you go to www.sewing.about.com, http://sewing.about.com/od/sewingmachineindex/ss/windbobbin.htm there is lots of helpful sewing machine pages too, general threading up, trouble shooting and getting the right needle for the job. How you wind the bobbin is important and you need to put it into the bobbin case the right direction so the thread comes off the bobbin then reverses direction through the tension spring.
Great video on You tube too which should help you http://www.youtube.com/watch?v=KHl-j4pYx4I
visually its so much easier than trying to describe the steps. But once you've mastered a bobbin case and bobbin system, they are all very similar between makes and models.
Jul 25, 2011 | Sewing Machines
Just want a maintenance manual so I can oil my Elna 740 Excellence sewing machine. Emailed the company, but they tell me just to have it done with service visit once a year. I want to oil the machine...
The manual should show you how to clean out the rotary hook area by brushing it out with a little brush provided in your tool kit. It should also show you how to remove the bobbin case and clean under it. Important: if you haven't removed the bobbin case before, then please take photos beforre you start so you can get it back into the right position when you have cleaned underneath. There may be two red marks on the case and surround to match up but I couldn't actually get a close up image of this model to check this.
Here is image from my Janome 6500 manual for this procedure, it should be similar on your Elna 740.
There is probably also an oiling wick in the centre of rotary hook under the bobbin holder. Remove the needle plate, pressure foot and needle, then take out the bobbin and bobbin holder and underneath is a circular metal part with a hole/depression in the centre. Wick will be inside there, don't mess with it!!. Just brush the whole area out, removing the lint from the brush into your bin. Don't try to blow the lint out with compressed air either.
You can add a drop of good quality clear sewing machine oil to the wick every couple of months or so, but keeping the area clean is equally a good preventative measure.
May 09, 2011 | Elna Sewing Machines
Where do I oil my elna 2007
This image shows that you need to oil the needle bar bearings and the rotary hook area. Also, always brush clean the rotary hook area after each use as keeping lint ouf of moving metal parts will prolong the life of any sewing machine and let the oil do its job.
Also, use good quality clear sewing machine oil, just a drop in the points indicated.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
I have an elna 7000 it has suddenly in the middle of sewing running but not sewing. Cleaned etc and saw that the rotary hook underneath is not taking up the top thread (including the bobbin thread
Have you changed the needle and perhaps put it in backwards? this would prevent stitches from forming as the rotary hook goes around.
However, worst case, would be that the timing is out and may need to visit the mechanic to resolve if this is the case.
Feb 06, 2011 | Elna 2005 Mechanical Sewing Machine
How do i oil my bernina 801?
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Dec 02, 2008 | Bernina Artista 180
Sewing Machines Logo
1,637 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
