Cars & Trucks Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change 20 Amp fuse in Position 11 in fuse box of 2007 Dodge Ram 1500. It's a mini-fuse, but is encased in a plastic insert (almost normal fuse size). Insert pulls about 1/2 inch out and stops. Is there a "special" puller for the insert? Its the fuse for radio/remote door unlock module Thanks,
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
  • Posted on Dec 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
Helped
51521
Points
257
Yes there is a special puller usually located in your fuse panel it will look like little plastic scissors if not if your carefull needle nose pliers will work good luck
2012 Dodge Ram 1500. Which fuse is the tail light fuse on it please?
Question edited for clarity.
Question moved to model category.
There is no specific fuse for the tail lights. It is likely to be the bulb or its connections / grounds. Diagnosing in this link.
https://www.google.com/search?q=2012+dodge+ram+1500+left+tail+light+not+working
2012 Dodge Ram 1500 fuse box diagram
StartMyCar https://www.startmycar.com > Ram 1500 > Fuse box
2012 Dodge Ram 1500 fuse box diagram ; Fuse MINI. 30A. M12. Radio/Amplifier ; Fuse MINI. 20A. M13. Main #2 Instrument Cluster/Wireless Control Module/ITM/ Siren/ ...
Fuse Box Diagram Dodge/Ram Pickup 1500/2500/3500 ...
Fuse Box Diagrams https://fuse-box.info > dodge > dodge-ram-ram-truck-...
Here you will find fuse box diagrams of Dodge Ram (Ram Truck Pickup 1500/2500/3500) 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017 and 2018, get ...
2006 Dodge Ram 1500 5.7 Hemi. What's wrong with my truck?
Dodge Ram 1500/2500 (2002-2009) fuses
Fuse Box Diagrams https://fuse-box.info > dodge > dodge-ram-1500-2500...
Fuse box diagram (location and assignment of electrical fuses) for Dodge Ram / Ram Pickup 1500/2500 (2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009).
Not good fuses to blow. you need to find out why?
31
31 10 or 15 amp except SRT (2006) (15A): Shift Motor and Mode Sensor Assembly (ETC), Powertrain Control Module (Gasoline);
2007-2008 (10A): Powertrain Control Module;
2008-2009 (15A): Powertrain Control Module
40 20amp
Base: Power Outlet - Instrument Panel, Power Outlet - Lower Console (2007-2009)
Here are your dash warning lights. The lightning bolt is Electronic Throttle Control, and you can't drive without that. Not sure that your sail and sun is unless it is the Cold Ambient Derate Mode Indicator
You need a local auto electrician. you can't guess stuff like this, it needs a pro grade scan tool computer.
https://www.google.com/search?q=auto+electrician+near+me
2answers
2008 Dodge Ram 2500. Where is the horn relay/fuse on it please?
Fuse 45
Fuse-Box.info https://fuse-box.info > dodge > dodge-ram-1500-2500...
2006 Dodge Ram 1500 5.7 4x4. What fuse runs the 4x4 please?
It isn't specified. There is more than one fuse that covers transmission. You would need an auto electrician or a transmission expert to connect a pro grade scan tool computer and diagnose if the switch or solenoid is faulty. A scan tool at this level is bi-directional and can command solenoids to operate and confirm that they do.
Fuse Box Diagram Dodge Ram 1500/2500 (2002-2009)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram
https://knigaproavto.ru > ... > Dodge > Ram (Pickup)
Nov 16, 2018 - 2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram ; 5, 20, except Base: Sunroof ; 6, 40, Diesel ('06): Wastegate Solenoid, Drive Fan Radiator ; 6 ...
2006 5.7 ram 1500 fuse box diagram - DodgeForum.com
https://dodgeforum.com > ... > 3rd Gen Ram Tech
3rd Gen Ram Tech - 2006 5.7 ram 1500 fuse box diagram - I was hoping somebody had a fusebox diagram kicking around. The inside of my fuse box cover does not ...
Fuses and relay Dodge Ram 2002-2008
https://fusesdiagram.com > Dodge
Mar 27, 2017 - For Dodge Ram 1500, Dodge Ram 2500, Dodge Ram 3500 - 2002, 2003, 2004, 2005, 2006, 2007, 2008 model year. Cigarette lighter fuse - Fuse box in ..
2006 Dodge Ram 1500 Quad Cab 4.7 V8. Where is the fuel pump relay and fuse please?
Question edited for clarity and add maker.
In the link
2helpful
Need location of fuse box .headlights suddenly stopped working on my 1991 318 Dodge Ram D250 Pickup
The fuse box you need is under the hood near the battery. It's a large black box, usually held closed with clips. There should be a fuse layout diagram on the inside of the cover panel you take off. Check fuses B, C, E, F and G. B, C, E and G are 15 Amp fuses. F is a 20 Amp fuse.
Try the web link below for the layout and listing of the fuses.
https://fuse-box.info/dodge/dodge-ram-1500-2500-3500-1994-2001-fuses-and-relays
6helpful
2answers
2007 dodge ram 1500 fuse box cant find aftermarket one .one from dodge is $600.
The fuse box is actually called a TIPM totally intergrated power module. fair common problem on dodge trucks sad to say. it has the front control module attached to it.
I acquired a 07 Dodge Ram. The interior auxiliary power ports don't work. I discovered that the fuse is missing. The rest of the fuses are mini fuses bit this one slot has a three pin ( 3 pins in a row...
you need to look at your owner manual or or shop manual see what kind and what amp fuse it take replace it with right one ,if is out may be it had some problem they have moved it ,good luck
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
