Question about Bosch Nexxt WTMC 3300 Electric Dryer
I have a 2004 Nexxt Dryer and the the lint filter light is staying on.
The lint filter is clean but the lint filter light is still flashing and now the dryer will not turn on. I have unpluged the dryer and checked out the exhuast duct in the back of dryer, everthing is clear. still not working.
  • 5 more comments
  • Anonymous Jul 19, 2008
    I have a 2004 Nexxt Dryer and the the lint filter light is staying on. I also tried to unplug it and blow out exhaust. Where is the thermal fuse.
  • janeck Feb 07, 2009
    Exact same problem... this is a horrific design flaw. I've even left emails at the Bosch site and no response :-( I go through a painful process at least once a week of trying to get in and clean out the residual lint that does not even make it to the lint filter but gets stuck in the grate between the dryer drum and the filter.
  • Anonymous Mar 01, 2009
    I have the same problem. I've cleaned the lint trap out and even washed it with soap and water and I still get the light.
  • Anonymous Mar 18, 2009
    I have the same problem and have not been able to fix it. the lint filter is fine and I have to turn off the unit and turn it on for it to start working again. then after a few minutes, the same thing happens. it takes me starting and stopping the unit over 10 times to dry a load.
  • cbmoore1 Apr 05, 2009
    I am so sick of this dryer!!!! this is my second in 4 yrs. and within a wk of the first one they replaced because the lint light goes on stays on, and will not work!! I have cleaned lint trap with vacuum and alittle vinegar water (I have done all the troubleshotting) and still will not work
  • Anonymous Mar 16, 2014
    unable to clear controls
    Nexxt dryer lint filter light flashes, won't start
Same problem
Posted on Jul 29, 2008
    Champion:
  • 210 Answers
Probably blew thermal fuse.
Posted on Jul 12, 2008
Lint light flashing
The problem may be with air flow through the lint filter screen. The filter is a fine screen and even though it appears to be lint free, it may not be. Spray the screen with a degreaser, use a soft brush to gently scrub it, and rinse under running water. This may solve your problem.
Jun 30, 2014 | Bosch Nexxt 500 Dryer
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer, E:01 and lint light flashing. nothing is stuck in the door.
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 26, 2010 | Bosch Nexxt 500 Dryer
Lint filter light flashing...on off light flashing. Cleaned lint filter and checked vent. Vacumed and brushed out lint area. Will not turn on.
We had the same problem as many here have described. After cleaning out the vent system with compressed air and a vacuum cleaner, the appliance still failed to start. I unplugged the unit for a few minutes, turned it back on and it still failed to start. I turned the rotary dial to "SHORT" pressed start and it worked!!!! Not sure if thats the magic sequence or i just got lucky but Good luck.
May 15, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
Had the same problem. I clean it the way you mention with the addtion of blowing compressed air through the vent pipe and it still failed to work. I unplugged the power for a couple of mintues, still did not work. I rotated the dial and pressed start at each position. In the "SHORT" position, it worked and subsequently worked in all positions there after.
Mar 28, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Dryer was not staying on for more than a few minutes - then was not staying on period. Replaced the timer. Dryer seemed to work fine but the problem of it not staying on has returned. What would be the...
Maybe the vent chamber is plugged (considering you have kept the filter clean) Pull the filter out, and look down in the unit for excess lint. You may have to move the dryer to clean it all out.
Jun 05, 2009 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
991 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
