Question about Onkyo Audio Players & Recorders
How do i install my surand sound and cable box to my LG television so the cable is ran through my surround sound and goes to my television? also how do i hook up my surround sound to my television?
  • 151 Answers
If you have a scart cable going to tv from cable box all you have to do is put a phono cable from tv to system input,this could be "aux,sat,tv,input",switch system to input you put phono cables into and set to prologic2,you now should have sound.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
What type of connection do i need to hook up my surround sound to my tv? so i dont have keep switching it over from my cable box to my gaming system. can you help me?
I just plug the rca cables from the GameSystem into the surround sound with the video cable(Usually Yellow) to the TV. This way the Game System goes through the Surround and the Surround is still hooked up to the TV normally.
Hope this helps!
Dec 13, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I have a brand new LG 50 plasma and a Bravia Sony surround sound system as well as a Cox Cable HD DVR box. I currently have it connected as such: HDMI from Bravia Sony System direct into TV HDMI from Cable...
you may have to set the input value on the bravia for optical on the input from the cable box. sometimes there is more than one way for a particular input to receive an audio signal, you may have rca(red and white), a black or orange rca type for digital, and then the optical. i would suspect you have to tell the bravia how the sound is inputed into the bravia. also , just a thought.... on the cable box there should be a volume control on the front of the box........ make sure the cable box volume is ALL the way up (it is the preamp volume).
Dec 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
I have a LG plasma, do i need a optical digital audio out cord to use surround sound?
In order to get true 5.1 surround sound you need to use either digital optical (fiber optic) cord or digital coax cord(RCA style ends) to link between your TV and your digital source such as DVD,digital cable box,digital satelitte receiver.You can route the audio through the TV but that's not the best way to go,I recommend going directly from the digital source to your surround sound receiver for optimum sound. Good luck !
Nov 29, 2009 | LG 42PX5D 42 in. Plasma HDTV
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Jul 11, 2008 | Insignia LCDTV26 26 in. Television
LG 42LC2D Hooking up surround sound
are you going through a cable box ? if so, then just connect the video out cable from the surround system to the video in on the side of the LG. Then connect the left & right audio in cables into the cable box coming out of the sound system, this will work, I just set mine up this way, any other issues let me know.If you are not using a cable box then simple connect out of the sound system the left & right audio out cables AND the video cable into the side of the LG ( the left side is where these in puts are).
Apr 20, 2008 | LG 42LC2D 42 in. LCD HDTV
Using surround sound
Good Day;
Connect HDMI cable to TV then audio cable back to "SS".
Good Luck, big IRISH.
Dec 15, 2007 | Hitachi 53UDX10B 53" Rear Projection...
178 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
