Question about HP Officejet 5610 All-In-One InkJet Printer
Error message 222aO-reset power come on when I turn on printer. I have plugged and unplugged all cables and power sources.Any solutions to this?
    Novelist:
  • 106 Answers
the error message you encounter is new to me. however, you can try to partialy reset your printer.
1. while the unit is turn ON, unplug the power cord from the back of the printer
2. press and hold the # and 3 buttons together and dont release.
3. while holding the two buttons, plug-in back the power cord from the back of the printer.
4. wait for a couple of seconds, it will give you a message on the printer screen "PARTIAL NVM RESET".. when you see that message, you may release the two buttons.
5. in some cases, after you plug-in the power cord button frmo the back of the printer, the printer will become ONLINE.. and after 30 seconds it will automatically turn off. when that happens, just release the two buttons and press the power ON button to turn it ON.
6. after turning it ON, it will give you message "PARTIAL NVM reset".
note: after performing the steps, your printer will make some noise and it will eventually stops. then try to check if you still have that error message.
- adonscott -
HP TECH
Posted on Jul 02, 2008
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
I have a HP photosmart 3310. I'm getting the error:Oxc18a0101 message. I've tried a couple of suggested solutions ut neither has worked. Help!
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone
Try this and it works
Regards,
Ron
Mar 26, 2011 | HP Photosmart 3310 Printer
PHOTOSMART D7360 - INK SYSTEM FAILURE
8- the error message 0xc18a0001 "Ink System has Failed" is now gone.
Regards,
FixYa
*Please rate this solution with Thumbs Up
Nov 27, 2010 | HP Office Equipment & Supplies
Oxc18a0101 error message ink system failure
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing error oxc18a0101
Try resetting the printer:
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Unplug the power cable from the All-In-One aswell as the power outlet.
Leave it unplugged for atleast 1Min.
Then plug the power cable directly to wall outlet without any surg protector.
And then press the # and No 6 button in the All-In-One and the without releasing the buttons insert the power cord untill it showas up a message as Semifull reset.
If the Printer turs off then release the keys and turn the All-In-One On and then try.
Good Luck
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Ink system has failed: Error oxc18a0306
3- Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
4- Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
5- Press both cancel and power button at the same time.
6- Message on printer screen will be, "Enter Special Key Combo".
7- Push keys; Left-Ok-Right.
8- When printer screen changes, scan through and look for "System Menu" and push "Ok"
9- Scan agan and look for "Clean Derivative" and push "Ok". [WAIT FOR 1 MINUTE].
10- Scan agan and look for "Clean Firms" and push "Ok". [Again WAIT FOR 1 MINUTE]
11- Press "Cancel" 4 times
12- Turn off power and unplug from power source. [NOW WAIT FOR 2 MINUTES].
13- Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
14- Plug in power source,and turn on power.
15- When printer boots up, answer the questions on the printer screen for your area.
16- The printer will cycle the ink from the cartridges to the print head and back.
May 20, 2008 | HP Photosmart D7160 InkJet Printer
Help!!!
/Putte
Mar 18, 2008 | HP Photosmart D7160 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
109 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
