Question about GPS
My HTC TyTN II GPS does not appear to work. I have bought the device, and when I first installed TomTom the device was able to get a GPS fix, Howeve after I ran external GPS, the device no longer seems to get a GPS fix and within TOm Tom the lower left sectio no fthe screen displays, 'No GPS device!'. The TOM Tom is configured to use the internal GSP however this message still appears Have I accidentally diconnected it from the internal GPS receiver? Help wuld really be appreceiated Cheers Bill
  • aniga01 Jan 04, 2009
    I also have the same problem, did you by any chance found a solution for this issue.
    Many thanks
  • faribb Jan 13, 2009
    HI guys , i have same problem and i thought maybe my gps broken , pls if u find any way to work with that let me know
I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
I Was lucky that mine worked again after a SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?
People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Posted on Jul 27, 2009
My htc tytn ii stays on align screen after hard reset
It seems it might be a problem with the installed ROM (corruption of some sort).Installing an original ROM (which can be downloaded from HTC's site) should fix it.
http://www.htc.com/www/supportdownloadlist.aspx?p_id=13&act=sd&cat=2
Mar 09, 2011 | HTC TyTN II Smartphone
HTC TYTN II GPS Settings
gps settings on a kaiser(tytn ii) are internal, that is the only setting you need to know. Please explain in greater detail what your trying to do, with what program, what version and what isnt working
Feb 27, 2011 | GPS
TomTom Navigator 6 and HTC Touch Pro 2
Start
Settings
System
External GPS
Programs tab - select COM4
Hardware tab - GPS hardware port = (None), Baud rate = 4800
Access tab - Check the box for "Manage GPS Automatically"
Hit OK
Then open TomTom
Touch the signal bar then the signal bar again
OR
Go to Preferences then Show GPS status
Hit - Configure
Select - Other NMEA GPS receiver
Ensure the baud rate is set at 4800
hit Done
Select COM4:
Feb 16, 2010 | Computers & Internet
HTC TyTN II flashed memory no sound
Check if you coincidently mute the phone. If its not the software then looks like the speaker is bad. Send your HTC TyTN II for repair to Dr. Cell Phone.
Dec 31, 2009 | HTC TyTN II Smartphone
HTC Tytn II - Win 6.1 GPS problem - No satelites
check in the tomtom settings which gps device you are using. i cant remember which typ mine used but you can check and try them all, also mine was on com4 but im not sure if this was standard. if you have the right settings, the with xda-developers.com for radio updates and driver updates. also update your quick gps
Nov 07, 2009 | HTC TyTN II Smartphone
Mobile phone instillation cd missing (HTC TyTN)
www.getprice.com.au/HTC-TyTN-II-Fixed-Install-Holder-ClicOn-Gpnc_34--23443497.htm
May 21, 2009 | HTC TYTN GSM Phone
Activate GPS on HTC TYTN11
HTC tytn II, att tilt,Kaiser ( all the same products) have internal GPS chip installed just near the camera , so you need not buy anything else. Just get google maps app, a internet connection and try to find your self by using locate me feature on google map, the GPS chip will point you on map with very much accuracy.
Oct 06, 2008 | HTC TyTN Smartphone
TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
May 12, 2008 | HTC TyTN Smartphone
GPS Logo
1,155 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
