Question about HP Pavilion dv1000 Notebook
Keyboard or motherboard?
HP Pavilion DV1000 laptop. T, Y, B, N keys do not work. Disassembled keyboard and cleaned and inspected all contacts, circuits, ribbon. No visible damage.
Disassembled computer and cleaned and inspected everything. Small carbon deposit on outer edge of board near expansion port. I assume this indicates something shorted out.
My question is, how do I test to find out whether the problem is the keyboard or the motherboard? An external keyboard plugged into a usb port works fine all keys. I don't want to spend money on a new keyboard if the problem is really the motherboard.
Computer sustained a spill a couple of years ago. Also dropped on its edge once and sustained a broken usb port.
  • DIY N Pray Jul 05, 2008
    You are correct. Replaced keyboard--everything working fine. Thanks!
  • DIY N Pray Jul 25, 2008
    purchased new keyboard on e-bay <$30. Works fine!
    Scholar:
  • 119 Answers
Its your keyboard thats the problem because if it was you mboard or one of the tracks in the circutry is the keyboard connection panel you would have a problem using all the alphabetical keys because they are all connected to the same track.
Posted on Jul 05, 2008
  • castatroy Jul 10, 2008
    Goood Thanks
I openup my hp dv1000 laptop and windows is corrupt.
first remove battery and power cord and then restart with just the power cord and see if that resets and fixes it.
If not, plug in an external keyboard and if it works then would mean your keyboard is dead and u will have to buy and replace it.
could mean motherboard too but try the other things first.
Mar 06, 2010 | HP Pavilion dv1000 Notebook
Laptop keyboard replacement on a hp privilian zv5000
i think the circuit under "G" key is not functioning due to short circuit.
i recommend to bring this to technician for repair or buy a new keyboard since this is cheaper.
Aug 14, 2009 | HP HQRP Replacement Laptop Keyboard for HP...
The keyboard of my hp dv1000 does not work. some
It sounds like your keyboard may have bit the dust !
If you can get to a DOS Prompt or word pad to check, I will explain.
Start with going across all the top key's. If you find one that does not work, go directly below it and see if that key left to right works. If not your connection is corrupt and the keyboard should be replaced. Example: Type Y and U if the U does not work go below to the J and K, if they don't work, 1 or more of the integrated connections are bad and you will more that likely see at-least 8-10 more key's in that region that also don't work.
Keyboard for the DV1000 units can be purchased for $16.00 to $30.00 US. on (ebay)
Replacing the key board is not a bad job, but will require a little time.
Good luck.
John@johnrraycomputer.com
P.S. DV1000 units are fairly old and you got your money's worth out of that one. !
Jun 10, 2009 | HP Pavilion dv1000 Notebook
I need open the Lap for clean the keyboard
You can lift the affected keys off the keyboard to get at the key contacts. Clean with solvent spray cleaner under the rubber contacts.
The keys can be replaced by positioning over the plactic hinges and pressed home until it clicks into place.
If this doesn't work you will need to replace the keyboard.
Keyboard replacements are available on the Internet, I replaced one from Yall Store for approx. $60
Go to www.yallstore.com
May 15, 2009 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 laptop pc keyboard not working properly.
Does this computer KB work alright in SAFE mode? If it does then drivers and/or viruses are the problem. If it doesn't work in SAFE mode then it could be drivers and or keyboard. Now try booting into BIOS. At the date prompt you usually can type any keyboard letter. If the keyboard works here, then you definately have driver/virus issues. If not replace the keyboard.
Mar 12, 2009 | HP Pavilion dv1000 Notebook
DV1000 KeyBoard Replacement
you press just enough to hear it click. Light pressure... You will feel the difference when it snaps into place.
Nov 27, 2008 | HP Pavilion dv1000 Notebook
HP PAvilion DV 1000 Keyboard Problem
Seems like it actually may be a problem with the keyboard. Could be that those particular buttons are faulty. I would try a new keyboard. They seem to be cheap enough these days!!Hope this helps!
Oct 01, 2008 | HP Pavilion dv1000 Notebook
HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Jul 23, 2008 | HP Pavilion dv1000 Notebook
HP laptop keyboard problem
I am looking for instructions on the use of the multi function keys on my lap top. I have asked at future shop were I purchased it with no success.
May 03, 2008 | HP Pavilion dv1000 Notebook
DV1000 manual for replacing keyboard
Dear Trent, I am sorry to hear about the keyboard/milk disaster.. :)
Please find all the info that you need about removing the keys or the complete keyboard at the following guides and HP service manual. I Hope you fix this!! :)
The following guide is for the keys.
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides available for the DV1000 but this guide will be more than enough to help you through this one.
The complete process for the keyboard replacement is here (Section 5.9)
http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Apr 02, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
323 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
