Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
KUDI01FL stopped running and will not start. The Clean LED light blinks 7 times, pauses, then blinks 7 times again. I want to reset the system to clear the error, and try running it again. I tried turning off/on the power to the dishwasher, but that did not reset the system. I had a problem last year and had a tech visit who entered a key sequence to reset the system. Does anyone know they key sequence to reset this model? Thanks.
  • Anonymous Nov 16, 2008
    Clean led keeps blinking. How do I reset it. Whats the sequence
  • 25 Answers
Try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
Can someone tell me the sequence code for my kitchen aid dishwasher
Posted on Jan 31, 2009
  • dmlr2 Jan 31, 2009
    what other question send it to me
2 Suggested Answers
SOURCE: what is the reset sequence
Kitchen Aid - KUD102FRBL1 - Black dishwasher with buttons on the top of the door...
Problem
Cancel light is on, blue power light is flashing 7 times then a pause.
Solution
Normal > HeatDry > Normal > HeatDry (all lights light up)
Close door. Slide an implement into the gap at the top and press the Cancel button twice.
Bingo!
Posted on Mar 22, 2011
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
Heat Dry - Normal - Heat Dry - Normal or
High Temp - Air Dry - High Temp - Air Dry
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Blinking "Normal" button
cleared.
causes below.
■ Open in heater.
control.
Diagnostics cycle.
power.
circuit.
See “WASH PUMP WILL NOT
PUMP”.
■ Faulty or sloppy door latch
closure force keeping strike
■ Faulty door switch (high
resistance).
series with motor and heater;
power.
switch contacts while checking
assembly. Confirm switches not
loose from assembly. Check strike
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Sep 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Clean light flashing 7 times. Can't start the machine
For KitchenAid Whirlpool KUDS01FLSS0 -- When the clean light is blinking or flashing 7 times in a row and no other front panel controls will work, do the following:
push SaniRinse-EnergySaverDry- SaniRinse - Energy Saver Dry
(Try the Heated Dry button if you don't have a Energy Saver Dry button)
All the lights will then come on as this will put the unit into diagnostic mode.
Then, push Cancel after about 10 seconds. You are no longer locked out. Run the dishwasher normally.
References:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9/$FILE/8178496.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Jan 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
3,969 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
