Question about JVC AV-32230 32" TV
Black static on tv
Here is picture of what my tv is doing. It used to go away when I tapped the side of the tv, but now it stays. It is a type of static.
  • giggles17599 Jul 06, 2008
    I bought the manual that was suggested, however from a different site, since the one I needed was not on the site suggested. I see there are hundreds of capacitors in the tv and I need to know how to find out which one or few need to be replaced. Is there something specific I should be looking for?
    I have tried the hard reset method multiple times and it does not work.
  • 1,512 Answers
Hi
The set will have dry solder joints in and about the horizontal circuit. I suggest pulling the chassis out and resolder anything that looks suspect, particularly around the fly back transformer assly and horizontal stages. If you are not sure, then you should get a repair out to have a look for you. remember TV HAS DANGEROUS VOLTAGES.
Posted on Jul 06, 2008
    Sergeant:
    Champion:
  • 230 Answers
Try the hard reset method ,that is,unplug all the cables and then leave the tv for half an hour and thren replug all the cables and try .Otherwise there will be some connections left inside ,so check that
Posted on Jul 02, 2008
    Genius:
  • 2,035 Answers
This is due the defective capacitance you need change the capacitors: I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck.....................
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Sanyo 47 inch black shadows
tried to reseat the connectors going to the t-con board.
May 07, 2013 | Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
I have an old tv, a small one, that works OK when you first turn it on, then after 5 or ten minutes the picture goes black. But, the picture will come on briefly if you lightly tap on the top of the TV (or...
Hi
There's a solder connection, probably on the CRT board that s going bad. It's an easy fix but if you're not trained to be working on CRT tvs I suggest finding someone who is. Good luck
Mar 05, 2010 | Zenith Televison & Video
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Sony Trinitron KV-29RS36C
more than likely there are numerus bad solder connections in the set. give the set a light tap on the sides and see if the picture returns, if it does locate and repair bad solder connections. most of them may be found on the G board. the A board may have several as well. in the past I have seen the delay line have the bad solder which drops the picture out.
Jan 12, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
TV Black-out
a tap on the side tells me that it's a solder connection broken loose, most likely in the horizontal section. if you have experience with electronic soldering, you can fix it, otherwise take it to somebody that can fix it. thermal expansion and contraction(from turning the set on and off) eventually produces metal fatigue in solder connections, and the connection breaks loose, just enough that it sometimes works, and sometimes doesn't.
Jun 28, 2006 | Sony KV-27S20 27" TV
JVC AV-32230 32" TV Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
