Question about Dryers
Dryer not turning
Hi
My Zanussi tumble dryer is heting up and making all the right sounds but the drum is not turning.
help
  • mookie23 Jun 29, 2008
    dont know
Is the belt broken?
Posted on Jun 29, 2008
  • jbscrd77 Jun 30, 2008
    If the unit is making "all the right sounds" this means the fan is running, directly driven from the motor, I would suggest you unplug it and remove the top cover that will allow you to see the drum and establish whether the belt is intact or not, it will be located around the drum. If its not there or its very loose then it is broken and you will need to replace it. Have a go.
    John
Zanussi tc470
DEFO BEARINGS WHEN YOU SEE THAT DUST A REAL SIGN
Jan 22, 2014 | Dryers
Fit felt drum seal to zanussi td4212 w tumble dryer
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps
Feb 12, 2010 | Dryers
Dryer working but no heat
Your dryer has two separate fuses, one to turn the drum, and one to heat it. It sounds like you have a broken fuse. Unless this is a new installation, then you need to make sure you have the proper electric cord attached. If it's mistakenly connected with a range cord, it won't supply enough power to the dryer.
May 20, 2009 | Zanussi TC7102W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Making an electrical noise, but drum not turning. Sounds like it's shorting.
I'd suggest - remove the top cover. Switch on. Push the drum around - see if the drum picks up speed and continues to run. If this happens, it means that the motor Starter capacitor has gone dud and will need replacing. Note- If the drum doesn't continue to rotate after you shove it, switch off immediately. It will likely then be a faulty motor.
Sep 13, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
185 people viewed this question
Top Dryers Experts
