Question about Beverage-Air MT45 Beverage Cooler Commercial
Water I get water in the in cooler inside tep 40
  • 478 Answers
Most likely a bad defrost tmer. Usually located at the bottom, locate this and advance the timer untl it clicks. Another solution is to unplug for 48 hrs with doors open, plug back in check drian line, if it cool down to below 35 its definitely a defrost problem. Ohm the defrost strip heater if good, check terminator (should be closed above 60 degrees). If good, replace defrost timer.
Posted on Mar 11, 2009
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
I am a single woman trying to prepare my mastercool for winter. I don't know how to remove the pads, so if insructions could be sent, it would be greatly appreciated. I don't know the size of the cooler,...
Is it a side draft or downdraft cooler? My instructions simply say to cover the unit, disconnect the power and drain the water for winter. They don't suggest removing or cleaning the pads until spring. If you're ductwork also is connected to your furnace, and you don't have a cookie sheet(piece of sheet metal that fits in a slot beneath mastercool unit or along the inside if it's a side draft cooler) then besides covering the entire unit you cn probably cover the blower, also called the squirrel cage, with a canvas cover.
Oct 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
Cooler freezing up
The system is most likley working fine.
The problem is moisture in side the unit. It needs to be dry inside or ice will build up on the cooling unit. make sure the lid is fully closed also.
Feb 28, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Beverage-Air MT45 Beverage Cooler Commercial Logo
164 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
