Question about Edirol UA-25 External Sound System
Stuttering sound when recording
Hi, I'm new to the world of home-recording and have just bought an edirol ua-25 to start recording on my laptop via cubase. I've been playing a keyboard through input 1 and the sound is good. However, when I put the click track on and actually try and record, there is a stuttering every few beats so the sounds goes out of time. I'm on Windows XP and I've an Intel Celeron processor (1.60GHz) with 0.99GB of RAM with plenty of space on my hard drive but I can't work out why this is occuring - any ideas?
    Scholar:
  • 68 Answers
It's crucial that you understand the concept of latency.
Latency it the time delay between the trigger and the operation.
In terms of computer sound recording and generation:
1) The time between the midi trigger and the sound generated by a software synth to come out of the speakers.
2) The time between the analog audio signal input to be converted to digital and stored on the hard drive.
3) The time between the digital audio track to be retrieved from the hard drive and converted to an analog signal that comes out the speakers or headphones.
4) All of the above at the same time.
The factors that contribute to this latency form a pipeline that include the A/D (analog to digital) device (UA-25), the software drivers for that device, the operating system, the recording application being used, the operating system again, your internal computer speed and your hard drive speed. Remember that the sound needs to go both in and out, often simultaneously (thats called full duplex).
A latency of up to 50ms is probably tolerable, but for optimum recording, it should be closer to 5ms. If you were to go over 50ms, you would need some sort of time compensation, whether automatic or manual, because nothing would synchronize properly, be it the metronome or previously recorded tracks.
"What's this mean, and how does it relate to my situation?" you ask.
Lemme tell you. The recording program and drivers will incorporate software buffers to adjust for slower components in your sound recording pipeline. Without buffers, or with too few buffers, the pipeline can drop information (sound) if it is not be able to process it quickly enough. This will often result in stuttering and skips. Sound familiar?
So why not just put LOADs and LOADs of buffers in the pipeline? You most certainly can, but for every buffer you add, you gain a bit of latency. And remember that too much latency is a bad thing.
"Ouch! I still don't get it. What am I supposed to do?" you ask.
I reply, "Good question, Grasshopper." You want to stop your stuttering. You need to increase the efficiency of your sound pipeline. For regular people this means the following, in order:
  1. Make sure you purchase an A/D-D/A device that has low-latency drivers utilizing one or more of the following standards: ASIO, WDM, MME or CoreAudio. Selecting the one that your RECORDING APPLICATION utilizes. ASIO is widely supported and good. WDM is the worst because it is really just regular Windows drivers, but they can sometimes be optimized for low latency.
  2. Make sure you install your drivers properly, selecting the one that your RECORDING PROGRAM uses.
  3. Make sure that your recording application has the hardware selected for your A/D-D/A device and the drivers that you previously installed.
  4. Make sure that your recording application is using ONLY the hardware specifically designed for low latency, which is your A/D device that you previously purchased and installed.
  5. Make sure you include as many buffers as you can while maintaining a low latency. Often, this is dependent on your recording application.
  6. Set the UA-25 to 44.1KHz or 48KHz, not 96KHz. 96Khz does not allow for full duplex.
Do these things and attempt to record something. If it stutters right away or you get "underruns" you need to increase your buffers. If everything is peachy for a while, but soon you start getting skips, try increasing the buffers, or get a faster hard drive or turn off some digital effects.
In summation: A Celeron 1.6GHz should have sufficient power to record, play and add a few VST plug-ins, maybe even a dozen or more. Chances are that your hard drive is fast enough to retrieve and record 16-32 tracks at a time. Turn off all the stupid, little programs that make icons near your clock, like the DELL support and Weatherbug and AIM and AOL and HP Monitor and anything that takes processing power and hogs memory.
Posted on Jul 03, 2008
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Every time i try to play any sound through my external sound card Edirol UA 25 my computer reboots it self for no reason. Any one knows why is that happening? my laptop is Advent 9115 and i have...
first try reinstalling the driver of your external audio device, but first uninstall it.
Also check the device itself it may have faults like shorts and the like causing the laptop o protect and restart.
Jul 02, 2010 | Edirol UA-25 External Sound System
No Sound From Channel 2 on my UA 25
My laptop is problems .sound driver is uninstalled
Feb 12, 2009 | Edirol UA-25 External Sound System
Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Nov 19, 2008 | Edirol UA-4FX External Sound System
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Playback recordings
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Jan 17, 2008 | Edirol UA-25 External Sound System
Recording sound
What operating system/ computer are you using>?
Oct 17, 2007 | Edirol UA-25 External Sound System
Edirol Ua 25 Making humm noise when recording Mic
I had the same problem, it was due to the charger i had for the laptop, this problem can be accomplished by purchasing STEREO leads. I do not know the reason they work, but if anyone does find out please tell me
Josh
Sep 16, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
615 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
