Question about Acme 6001 Juice Extractor
Unbalanced When spinning, it seems unbalanced. Can I fix this?
    Champion:
  • 356 Answers
TRY INSTALLING THE BASKET IN DIFFERENT
POSITIONS. IF THIS WORKS MARK THE
BASKET IN RELATION TO THE TOP MOUNT.
Posted on Jun 30, 2009
  • JOHN REILLY Jul 02, 2009
    THE ABOVE FIX SHOULD CORRECT PROBLEM WHEN JUICER
    IS EMPTY. WHEN JUICING SOME VIBRATION IS UNAVOIDABLE.
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
The filter that spins on my juicer is getting slowly clogged up despite being properly cleaned each time. About a quarter of the tiny holes are blocked. The brush that came with the machine doesn't help....
IF there is NO plastic on it, you can use heat from something like a heat gun or oven to bake it off. You might also try something like CLR or muratic acid BUT they are not that expensive to replace.
Oct 15, 2017 | Jack Lalanne Power Juicer 250 Watts
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
It will not turn on, i tried the reset button still no power. How do i fix it?
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Jul 11, 2009 | Jack Lalanne Power Juicer (Stainless...
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Acme 6001 Juice Extractor Logo
83 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
