Peugeot 406 cd player works when ignition is on but when engine is started cd player wont work. Radio is fine.
Just bought 2001 peugeot 406.The radio worked perfect but CD player not reading disk or operating.That was until I realised that the CD for driving safety will not allow you to put CD into it while driving or engine running.Switched off engine then switched it to 1st batt light position & CD worked perfectly.But when I then switched key off & then started it was back to not operating.I then realised that the CD player for safety will not operate when engine is running unless you let the CD start operating first pre engine fire then wait a little more time before starting .Now it should work properly though it will not allow even the passenger to change a disk while being driven. On disk change you have to go through the same start proceedure.Hope this will get your CD working.Sherlock ??
Posted on Oct 27, 2009
Why has my peugeot 406 wipers stopped parking? They just stop randomly
You clearly have a leaking power problem.
1) first check if the battery finaly died and can't hold proper voltage. If it is having 12V just before starting but drops fast a new is required.
2)This may be a long shot but give it a try. If one diode in the generator is broken you might see this kind of problem. With the battery fully charger try to disconnect the generator. Take care for shortcut of the cable taken off - it is still plus from battery. If the problems dissapear then the generator is ready for a being reworked. Do you know why the battery vent flat? if not this can be the same reason. With only one faulty diode the generator will still do some chargeing with engine running.
PS: while working with generator cables it might be a good idea to disconnect from battery until cable is secure garfa'ed.
Jun 17, 2014 | 1999 Peugeot 406
Radio cassette wont switch on a/c and fan and display all working
check your wiring. Mine had 2 positive wires. one ran the lights and certain things and other ran the radio/cassette etc. also check the ground wires same deal need both for every thing to work.
Apr 21, 2014 | 1999 Peugeot 406
Peugeot 406
check battery and charging system
Dec 02, 2013 | Cars & Trucks
My 406 1.8liter engine has a tendency to shot down when in idle and cold. after 5 miles it runs fine.
Sounds as though it may be the Throttle Position Sensor. TPS. It is on e the throttle body and sets the idle of the engine.
Nov 22, 2013 | 1999 Peugeot 406
Not old age, but heat. something behind the dash is creating heat, which is why things go dark over time and why it works aftt
Nov 16, 2017 | Audio Players & Recorders
Peugeot 406 hdi executive 2002 will not start
immobiliser problem main dealer me thinks
Aug 18, 2009 | Peugeot 406 Cars & Trucks
Radio not working on my Peugeot 406 HDi 90 (2002 model)
i have had the opposite problem from you my cd has gone but radio works check the back of it to see if the antenna has come loose if not the transmitter has gone in the stereo
Jan 07, 2009 | 2005 Peugeot 405
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
1,200 people viewed this question
 Grubhead
Grubhead
