Question about Konica Minolta DiMAGE Z5 Digital Camera
Mode Switch Have you a diagram of the mode switch mechanics as I believe the mode switch has broken a piece of plastic that moves the micro miniature slider switch on the pcb If you have, can you post it to graham.allder@btconnect.com Thanks
  • Jeff Mungle
    Jeff Mungle Jan 06, 2009
    I just recently purchased a used DiMAGE Z5 and I am puzzled with this one. I am pretty sure that it is not supposed to do this but here is the problem.
    The Mode Select dial itself has a tiny little bit of play in it up and down, (in fact it does not seem to me to be anything unusual) but when selecting "P" Program mode, "S" Shutter Mode or the "Sports Action" Mode the camera will not stay in these modes unless you push down on the mode select dial and hold it down. If you do not apply this constant downward pressure the mode changes to an adjacent mode right next to the one selected (the dial itself does not move but the program mode changes); for instance when placing it on Sports Action mode if you do not push down and apply constant pressure to the dial it will revert to Portrait mode which is next to the Sports action mode on the dial even though the dial is on Sports Action.
    Has anyone seen this problem before and how do I fix it????
  • 4 Answers
Its the switch itself that's broken. I just replaced mine, a challenging task due to its small size. Seems to be a common fault. I have these switches in stock.
Posted on Sep 21, 2008
It seems that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. How (Where) to reset the mode?
This could be caused by damage, anywhere in the mechanism. Look around for broken plastic parts first. Setting any VCR up out of sync is a nightmare, without the user manual near impossible. The mode switch will probably be out, it could even be the cause of the fault in the first place!
Sep 11, 2011 | LG MG64 VHS VCR
The brushbar on my model 17 didn't work. I found the micro switch next to the main motor wasn't making. There is a plastic piece that presses the lever of the micro switch to energize the brushbar...
I'm sorry to hear you're having difficulties with your DC17. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 05, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a ewv401 a. when we turn it off then back on the "tape in" light comes on when no tape is in it. we've also tried unplugging it but nothing works. how do we fix this problem.
Tricky one, chances are the mechanism is out of sync. It's sometimes caused by damage to it, such as a broken piece of plastic etc, this throws the mode switch out. The mode switch tells the electronics part what position the mechanism is in. IE: fast forward or eject. Sometimes too the mode switch has gone. So what you need to do is check to see if any damage has happened, it could only be slight, so keep your eyes peeled! Find the mode switch (I'll post some images of some to help you find it) and spray it first with Servisol Video 40 as the can get dirt in them. If you can't find any damage and spraying doesn't work, then you will need a service manual to reset the video up after you replace the mode switch. Without a manual (which take it from me) you will never be able to get mechnism set up right.
Aug 09, 2010 | Emerson EWV401 S-VHS VCR
After unplugging my vcr and replugging it in it began to say tape in but it doesn't have a tape in it
It might be the mode switch. This tells the computer chip what position the VCR is in. It can go out of phase due to dirt (Just spray the Mode Switch with Servisol video 40 to cure that). Or it can go out of phase due to a mechanical fault. IE: some plastic part has broken etc. The mode switch itself can wear out.
If cleaning doesn't work, or you discover a fault, the mode switch may be then out of position. Setting it up right will almost certainly require a manual. As they very often need to be set up when the VCR is a position which nine times out of ten is not the eject mode!
Jul 06, 2010 | Emerson EWV401 S-VHS VCR
STUCK ON STANDBY
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Sep 04, 2008 | Fuji FinePix A345 Digital Camera
Stuck in video standby mode! help!
Lori, the switch above the display may be broken. does it still 'click' at each of the 3 settings? (play,video,camera)
Mar 18, 2008 | Fuji FinePix A345 Digital Camera
Goldstar GVR-DD1
Even the service manuals are pretty bad at helping with mech problems like this. You just have to be very mechanically inclined to figure it out. A lot of VCR mechs are very similar however so this is where experience helps. You do need to get the circuit board off however. Usually a few screws up from the bottom. Pretty smart huh! - put the least reliable parts (the belts) in the hardest place to get to. Look carefully for little broken plastic pieces. gear teeth etc. Since the motors work some of the time, they are not the problem. Could be the mode switches are out of time. They are a set of switch contacts buried in the mech which tell the brain what position the mech is in. Move the load motor by hand (I use a 5V power supply with a fwd/rev switch so I can run it back and forth and watch the action.
Goldstars are good mechs. They make a ton of them and pretty well get the design bugs out, but of course those little plastic parts break easily.
Hope Ya Fix It.
Jan 24, 2008 | Goldstar GVR-DD1 VHS VCR
Canon A70 stays in replay mode
Gerry, The mode switch is a very common problem that causes the camera to remain in either play or camera mode. The stem breaks off the top of the switch and no longer functions. If this is not the case, the flex harness (operations unit) can get torn on top if the camera has been dropped. If the switch appears to be good, check for ground switching between the two outer legs of the switch, the micro gets a low signal from the mode switch to determine what state the cameras in. Good luck, this is a nice camera! Joe Weibel Custom Electronics (customelectroncis.org)
Feb 13, 2007 | Canon PowerShot A70 Digital Camera
RCA Camcorder
It's been a while since I worked on the RCA full size camcorders as well. It sounds as though the load motor is "jogging" because the mode switch is not in time with the mechanism. I think there are timing marks on all the cams and gears in the unit and an indicator arrow on the mode switch. Set the mechanism to the "stop" mode and align the main cam index mark to the load motor drive cam, be sure the mode switch arrow points to the load motor drive gear "hole", this tells the micro the unit is in "stop" mode. Good Luck Joe Weibel customelectronics.org
Feb 07, 2007 | RCA CC4252 Camcorder
Konica Minolta DiMAGE Z5 Digital Camera Logo
225 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
