Question about Garmin nuvi 350 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
Unit will not turn on at all...Please advise. The unit was working fine, the while driving, it just went out & could not get it to come back on,,,Reset button did not work...Please help-thanks. Lex garmin nuvi 360 came on when i turned it on but froze up on the ( I agree) screen. Would not turn off with the on/off button. So i pressed the reset button. The unit went off and will not come back on. The screen is black and when i plug the charge in, still no change.
  • 2 more comments
  • Anonymous Jul 02, 2008
    Garmin nuvi 360 will not come on. Tried reset button on back. Unit is charged.
  • eakin1 Aug 23, 2008
    Garmin c550. Turned on and it worked for 3 minutes and then went black. Won't turn on in several cars I tried.
  • MysticSol Sep 14, 2008
    Same senario, nuvi 360 was working fine and suddenly went dead. Won't take a charge or turn on. I tried your hold the power, push reset, hold power till it boots thing to no avail. I am pretty handy at fixing things myself and I am confident that I could open it and remove the battery as you suggested; however, I have read a number of posts on the web about how careful you have to be when opening it because the antennea wires are so delicate. I was wondering if you could give some intructions to kind of walk us through opening the case and removing the battery? Thank you, Mystic Sol
  • Anonymous Mar 25, 2009
    my gps won't turn on but reading Fix Ya on google, by resetting button on back, the gps now is on, Good luck everyone
  • 174 Answers
Push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Posted on Jul 23, 2008
Fridge warm freezer ok
the unit will be turn off if cleaning depend to your refrigeration design
Dec 05, 2012 | Refrigerators
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My fryer went nuts, it was on and working fine, the beeper went off and I went to check on my food and the unit was off. I unplugged it and plugged it in 4-5 times and nothing, tried it again in the...
Thermal safety switches are-common in heating type appliances. If this unit is so protected, a reset should be somewhere on the unit. Another component is a fusible link. This is basically a enclosed fuse that that will blow if a short or excessive current draw is present for an unusual length of time. The reset will kick everything back to normal instantly. The fusible link is generally inside the unit on the power in wire. This link should be replaced with its like. It will require soldering on replacement. This fryer is probably an expensive unit , so the cost of replacement opposed to repair should be weighed. Good Luck to you. Thanks for seeking your answers through Fix-ya. _Ned_
Apr 04, 2011 | Euro-Pro Kitchen Appliances - Others
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
First: alarm went off on its own.(mazda 6 2003). Now when locking and unlocking car sometimes indicators flash and sometimes not. Now red immobaliser light is flashing on dash when driving, then stops...
there is often a small back up battery in the immobiliser unit itself, if you can locate this unit and replace the battery with the ignition on / engine running, then it should not need recoding and work fine after that. The other thing that could be wrong is the key battery (if the fob has one) or the transponder chip in the key head. If the key signal is low the immobiliser lamp will light during driving, but this does not explain the alarm going off. That is more likely either a poor vehicle battery, alarm / immobiliser back up battery, or another electrical fault such as water leakage into a tail-light or even the alarm unit itself when it rains. A lot of alarms are voltage sensing and when the vehicle is parked they will alarm if the battery voltage changes for any reason, though not during driving so the battery in the immob is my first choice to look at.
Oct 24, 2009 | 2003 Mazda Mazda6
My gateway 7330GZ with windows xp doesn't se my dvd-rw drive
un-install the drivers,then re-install after first restarting the unit.
if that does not work,replace the drive with a new one.
Jan 31, 2009 | Gateway 7330GZ Notebook
Keys on Blackberry 8330 don't work
First I disconnected the battery again and let the unit sit for over an hour. Then I took the phone and went through every button to make sure that one of them was not stuck. For one reason or another after replacing the battery this time the phone started to work again. I had tried taking the battery out while it was turned on to reset the unit a couple of times. The 30 seconds they suggest, and 5-10 minutes. Neither of those attempts fixed the unit. I would say that letting the unit sit and checking for stuck keys allowed the unit to reset itself and everything seems to be working fine now.
Jan 28, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
LG LRM-519 Not responding to anythiing
I had a LRM-519 that would not get past a very dimly lit "hello" on the LED screen. I called tech support and was advised to make sure no disk was in the unit and turn off the power from the unit (not the remote) and unplug it from the wall outlet. While unplugged, hold down the power button for 30 seconds then plug it back in. This didn't work the first time, but after a few tries it worked for me. My unit hadn't worked for nearly 3 months prior to this. Good luck.
Mar 31, 2008 | LG Electronics LRM-519 Digital Media...
Garmin nuvi 350 GPS Receiver Logo
786 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
