Question about Hunter Heating & Cooling
Need p/n 73455-01 capacitor for fan 7.5 mf 250 wv 60 hz
    President:
  • 1,462 Answers
You should be able to source this from any good shop dealing with appliance spares. nothing unusual about the values
Posted on Jun 29, 2008
What is this 1-inch black box thing HDC E130486 CB 4 uF 5% 250 VAC 50/60 Hz with two black wires? Is it a capacitor, or Remote control receiver? What test to find if it is defective ?
the uf and % voltage etc makes it a capacitor
if you take it to an electrician it can be tested for it's capacity
it has nothing to do with the light as it is used to start/run the fan motor
if the light is also not working when switched on , check for the fault some where else
and to do that get in an electrician to ensure that it is wired right and the circuit is functional
Jul 08, 2016 | Dryers
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
I need de capacitador
It's capacitor. If you have the values off it you may find it at Eurton Electric.
Jan 12, 2014 | Craftsman Saws
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
Do you have a capacitor for makita circular saw 5903 r
there is no capacitor in that saw, you have other problems, what is it doing or not doing and I will try and help
Jan 08, 2012 | Makita Circular Saw - 15 Amp, 7 1/4in....
Need a 2 wire capacitor or an Aloha Breeze ceiling fan.
You can go to Radio Shack, and find them there. Just ask one of the workers there for what kind (Voltage and Capacitance ) you need. I happen to have one right here...
It is a 1.5 nano farad With a tolerance of 5%.
It is rated for 250 volts at 50 to 60 hertz.
Jul 19, 2010 | Aloha Housewares (93645) Ceiling Fan
GE Box Fan Motor ? No Capacitor?
mcdevito75 here, It could be bad brushes in the motor also, or a bad bearing or bearing cap in 1 of the motor ends.
Jul 27, 2010 | Dryers
Bought a TD 150 MkII that runs 100 ~ 240 volts 50 Hz. In my country we have 60 Hz. How to correct ?
It's simply a matter of if the transformer can take the 60 Hz. After that the supply passes via a large electrolytic capacitor which is there to take out the 50 Hz. Otherwise you get a hum, which is what happens when the large capacitor fails.
Though I can not be certain! It might just work with the 60 Hz without doing nothing. Though if you get a hum you might need to replace the big capacitor with one with a greater value than the one in. Say the one you have in is 2200uf at 50v, you would need to replace it with 4700uf or higher at the same voltage or higher. Of course the other problem might be getting a bigger capacitor in!
Jan 11, 2010 | Thorens Audio Players & Recorders
I have a sears bench grinder need new capacitor cap 10uf wv 250ac part number cbb 60-1 where can I get one
If you take that capacitor to a hardware, Heating and Air store they will probably have a replacement for it. The 10 Mfd and 250 WVAC are the main values and the physical size. No mater what the part number the main consideration is capacity and max working voltage. You should be able to find one that will work for you.
Oct 09, 2009 | Grinders
Heating & Cooling Logo
138 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
