Question about Hotpoint FFA70 Bottom Freezer Refrigerator
FFA70 The high temperature light has come on.  The food already in there is not defrosting and the food I have recently put in there is not freezing.  What can I do to get it freezing again?
  • reg1966 Jul 05, 2008
    Hotpoint FFA70 Fridge freezer,Freezer high temp light is on constantly,have already de-frosted and re-started,the light has stayed on and the freezer is not freezing.
    President:
  • 1,462 Answers
These machines commonly do not defrost sometimes an intermittant fault
remove back panel from freezer and if im right, the pipework will be iced up especially at the top. de-ice carefully with a hairdryer but don't blow hot air on the stats mounted on the pipework. turn on and check fan runs as well
Posted on Jun 29, 2008
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
My FFA70 Fridge Freezer has the Freezer high temp light on.. Food in top and bottom draws already defrosted overnight! HELP please!!!
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 28, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
There is power as the fridge is ok but the freezer is not frosting
Esto es un ejemplo de texto, con un video de prueba
Esto es una prueba
Jun 04, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
316 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
