Question about Stoves 27 in. DW60 Built-in Dishwasher
Stoves DW 60 main water 'arm' comes off!
When I open the door following a dishwasher cyle, the main water distribution arm has become free from the pipe section feeding the water flow. It can easily be placed back on, however, there doesn't seem to be much of grip between the male/female grooves. can this be replaced, is this just a wear and tear problem with te plastic (or nylon) used?
I had the same problem and replaced the rotor arm and o-ring underneath the arm. It fixed my problem.
Posted on Oct 23, 2008
Why does the lower spray arm keep coming loose on a Kenmore 587.15189402
Is this one of those drawer-style dishwashers, or a regular DW? I can't seem to find that model number in my search. If it's a regular (door-opens-downward) DW, then you probably don't have the lower wash arm attached properly. On some DW's you turn the hold-down "screw" in the reverse direction to tighten it. If it's a new Kenmore Elite DW, then you turn the lower square or geared section 1/8th turn clockwise to lock it. Of course, you may have a damaged or stripped plastic part that just won't stay....
Oct 20, 2014 | Kenmore Dishwashers
I have a stoves dishwasher i do not know model or serial no only just its a stoves DW 60 it turn on but as soon as the door is closed to start the wash it blow the trip in the fuse box
Its one of two things. Either its your heating element or your motor. Look underneath and also inspect for water having possibly splashed around. Remove both element wires from terminals and place them safely as not to touch anything when testing. If macine now doesnt trip off, you have found the problem. If it does, remove the motor wires and retest. If still tripping, check where power enters the machine. There is a line filter. on occasion it blows and shorts to earth.(remember, when removing these wires, pull plug out of socket.
Sep 21, 2009 | Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Detergent is not getting distributed through the wash cyle -
either the dispensor is not opening at the right time( should open 15-20 minutes inot cycle) however may not open till very end of cycle.. or your filter screen is clogged and wate ris not being sprayed onto door to rinse it out of dispensor
Mar 28, 2009 | Dishwashers
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Stoves 27 in. DW60 Built-in Dishwasher Logo
198 people viewed this question
Top Stoves Dishwashers Experts
Owen Barnes
Mike Cairns
Mike Cairns
 Russ Hill
Russ Hill
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
