My supernet 8000s Satellite receiver RED LED is ON, it Displays the CH number,but the Signal GREEN LED is OFF, no picture, even Dish signal is good on the dish pointer? Could you help?? Thanks.
  • 1 more comment
  • Anonymous Sep 10, 2008
    Same as described
  • Anonymous Jan 04, 2009
    Same problem.
    Do I need to replace it with a new receiver or anything burnt out inside the box due to transmitted signal problem?
  • Anonymous May 05, 2009
    red led. No green. What's it mean?
satscoop
  • 59 Answers
SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Posted on Oct 29, 2007
  • 2336 Answers
SOURCE: Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Posted on Feb 25, 2008
  • 319 Answers
SOURCE: hdmi or optical
There are no noticable differences between HDMI and optical except price. Although optical is less prone to EFM interference, HDMI can carry a wider bandwidth, depending on quality, but cost a lot especially long runs (10 ft or more). Also optical cables are not prone to connector tarnish which occurs even with gold pins of HDMI
Posted on May 07, 2008
  • 8 Answers
SOURCE: satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Posted on Aug 13, 2008
  • 374 Answers
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Posted on Sep 04, 2008
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
712 people viewed this question
 Grubhead
Grubhead
