Question about Liebherr KES3660 Stainless Steel Refrigerator
KES3660 Plastic drain reservoir under fridge is always full and overflowing. any ideas please? also ventilator fan wont work anymore? is problem related
  • 67 Answers
The ventilator fan causes the water to evaporate from the drain pan. There may also be a heater element to do it as well. Without it nothing is making the water evaporate so it is overflowning. Might be the fan motor or the switch that is a problem.
Posted on May 05, 2009
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Overflow reservoir
Defrost water trays are often made of flimsy plastic and likely to crack. Yours may have cracked. Another possibility is that the tray may have become mispositioned so that the water is not draining into it. The improperly closing door may have to be adjusted.
Nov 01, 2013 | AEG Dishwashers
Heater core replacement on a 1994 astro van
1 Drain the van's engine coolant. With the engine cool and the parking brake applied, remove the radiator cap, place a large container under the radiator drain and remove the drain fitting. After draining the coolant at the radiator, move the container to the engine block and remove its drain plug to drain the remaining coolant.
2 Remove the coolant reservoir by disconnecting the overflow hose from the radiator filler neck, removing the fasteners for this reservoir and the windshield washer fluid reservoir, lifting both up and separating the coolant reservoir from the other one. This is needed if the van is a 1994 model or older. On newer models, disconnect the reservoir for the windshield washer fluid by removing its bolts and moving it aside.
3 Detach the heater hoses from the heater core tubes at the firewall by loosening their hose clamps. Plug the core tubes with rubber to prevent contaminants from entering.
4 Reach under the dashboard in the van's passenger compartment and remove the screws for the heater core cover to remove it--the cover should have a half-cylinder shape. Remove the two mounting screws at the rear of the heater core and lift the core out of its housing.
5 Insert the new heater core into the housing and fasten it with the mounting screws. Connect the core cover back in place.
6 Unplug and reconnect the hoses to the heater tubes with their clamps. Reconnect any components (like the washer fluid reservoir or coolant reservoir) that you disconnected to access the hoses.
7 Refill the coolant after replugging the drains at the radiator and engine block. Add the 50/50 mix of water and antifreeze to the radiator until it's full and the reservoir to the lower mark. Run the engine in a ventilated area with the radiator cap off until the upper radiator hose is hot, shut off the engine and let it cool, then add more coolant up to the reservoir's lower mark.
Jun 27, 2011 | Heating & Cooling
I have a lieebherr fridge freezer model ctnes4653 and i have noticed that ice is building up at the back of the fridge (before it used to drain down the back of the fridge and evaporate). i thought of...
As you had done switch off the fridge. now after the frost had cleared off , keeping the fridge a little away from the wall switch on. But only after you have checked for the thermostat to be set to normal, the fan working fine as well as the timer switching on the auto defrost. So look out for the compressor to shut off when the thermostat reaches the limit, if this wont work then the ocmpressor will run and result in heavy frost. so it can be that the wires to the thermocouple is broken or damages due to frost. so you can open freezer compartment and confirm on inspection of the wiring for any breaks.repeat if frost appears till you correct and confirm. If you are calling a repairman keep this mind so as to get an idea of the work, to have an estimation of the work. Hope you try this out. Good day
Aug 10, 2010 | Liebherr KES3660 Stainless Steel...
Liebherr f/f, drain gully is retaining water, drain hole is clean
the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
May 05, 2009 | Liebherr KES3660 Stainless Steel...
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Dec 04, 2008 | Fisher and Paykel Active Smart E522B...
Drain pan fills daily
does drain pan have copper lines it
Feb 12, 2008 | Viking VCSB483 Side by Side Refrigerator
Fridge water "overflow" ?
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
Feb 11, 2008 | Refrigerators
Liebherr KES3660 Stainless Steel Refrigerator Logo
317 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
