Bra wire stuck in drum, not visable to the eye, how do i remove the drum paddle to remove the wire?
    President:
  • 1,462 Answers
Easiest way is to remove the heating element and the gap between the tub and drum will be exposed and you can fish it out.
moral - don't wear bras with wires!!
Posted on Jun 29, 2008
A bra wire disappeared in my front load washer. Now I hear it between the basket and the drum, dragging around. How can I get between the two to get it out? I believe it is stuck in one place at back.
This can be removed simply by taking out one of the drum paddles , 3 of them, take out one ,or you may be able to see it as I have done often poke head into the drum with a torch , chance is you will see it grab it with Long nose pliers? and pull out. Good luck.
Oct 01, 2016 | Washing Machines
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
Bra wire has gone through the holes in the drum and makes a dreadful noise when it rotates, there are now signs of the wire inside the drum. How do I get the wire out
Cannot make out if that is a typo. There are signs of the wire or there are not? If you can see the end of the wire, grip it with a pair of pliers and carefully work it out back through the hole it is stuck in. If there are no signs of the wire, look if you machine has any removable plastic paddles in it. If it has, remove one of the paddles, usually held in by screws and clips, and rotate the drum till you see the wire, and remove it. Also look around the front of the drum behind the door in case the wire is jammed in there. If all this fails there is only one solution and that is to remove the front of the machine and the front of the outer drum to gain access to the gap between the two drums.
Mar 08, 2011 | Neff V4380X0 Front Load Washer / Dryer
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
I need to get access to the drum, how easy is this to strip out?
if you remove one of the paddles from inside the drum you may be able to grab it with long nose pliers or wire coathanger.
put a small screw driver into the paddle's 3rd hole from the front to press in a metal tab carefully not to bend it completely and pull the paddle towards the front and it will come off.
if the bra wire is up the back of the drum you may be able to grab it with removal of the heater element round the back of the machine at the bottom of the drum, loosen the 10mm bolt,(not off clompletely) and wiggle the heater out.
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Apr 12, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Washing Machines Logo
225 people viewed this question
Top Washing Machines Experts
